Understanding Closed Forms of Series | Quick Explanation and Tips
  • Thread starter Thread starter iamaelephant
    Series
iamaelephant
Hi, I'm just going through an example of closed forms of series in a textbook (Anton Calc) and I'm wondering how they got to this step, can someone please explain it to me? Also, any hints on formulating closed forms would be greatly appreciated, they are not covered in detail in my text. Thanks a lot!
\sum_{k=o}^{3+n}{k^2} - 14<br /> =\frac{(3+n)(4+n)(7+2n)}{6} - 14
Sorry if it's a stupid question, but I've never tried working with a sum with variable at the top, and I don't know what I'm doing.
Given above
None, this is an example problem I don't understand.
Edit - there should be brackets surrounding the sum that cut off the -14 as it's not part of the sum. I couldn't work this out in LaTeX and I'm in a hurry.
Given above
the first part is the sum of first x squares (in this case x = 3+n)
\sum_{k=o}^{x}{k^2} = \frac{x(x+1)(2x+1)}{6} plug in x= 3+n then u get
of course u can prove these sums to the first "x" terms of k^n (in ur case it is k^2)..
Thanks a lot! Heh, always seems so simple when someone explains it :)
Is anyone able to give me some hints or links on how to find the closed form of any series? I'm really stuck here and my textbooks don't seem to cover it.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
