Understanding colors (Lights And Optics)
  • Thread starter Thread starter zzoo4
    Optics
Light interacts with objects to produce colors based on the frequencies they reflect or absorb. Primary colors of light are red, green, and blue, while secondary colors include magenta, cyan, and yellow. When shining yellow light on a red cherry, it reflects red because it absorbs the yellow frequencies, while a yellow banana reflects yellow light and absorbs others, appearing black under blue light. The perception of color is due to cone cells in the retina responding to specific light frequencies, and this process is known as additive color mixing. Understanding that colors correspond to unique frequencies clarifies why objects appear as they do under different lighting conditions.
zzoo4
Well, This isn't a homework , but today in class we talked about how lights shining on a object produce different color. But I do not know what color it produces??
I know that Primary colors of light are red green and blue. Secondary are magenta and cyan and yellow.
If we have a red cherry on the desk and we shine yellow light, Why does it produce or reflect red?? Teacher said it reflects green but how?
And vice versa if we shine a red light into a yellow banana, we get red
and if we shine blue, we get black.. why??
Can someone help me understand why these colors are produced and how i can tell??
light itself isn't organized as primary and secondary colors that is a result of your eyes ability to see color. You have three types of receptors:
http://en.wikipedia.org/wiki/Young–Helmholtz_theory
light itself is characterized by its frequency red light has a lower frequency than green or blue light.
the banana is yellow because it reflects that frequency and absorbs the other visible ones. as bananas age they go from green to yellow to brown (reddish) so its seems it would have a varying ability to reflect these colors but not blue and that's why you see black.
But what if you don't know the frequency. But just the color...
White light is composed of all of the frequencies in the visible portion of the electromagnetic spectrum. This means that all of the colors have a unique and corresponding frequency. Darkness is just the absence of light.
Whenever you "see" a color, this is the result of light frequencies being added together starting with darkness. This is called additive color.
Mixing light is not the same process as mixing pigments such as paint, crayons, or other dyes. Those "colors" are produced in a process called subtractive color in which the frequencies of light are subtracted from each other starting with white light.
The components in our body responsible for the perception of color vision are the cone cells located in the retina of our eyes and different cells respond to different frequencies of light.
So as jedishrfu has stated, when you perceive a that an object has color, it's because that the object absorbs all of the frequencies except for the ones that your photoreceptors respond to. Each color has a corresponding frequency; Theoretically, there are an infinite amount frequencies, therefore just as many colors. This is why the collection of colors is called a visible spectrum; It is a continuous band of frequencies. You can't separate a color from its frequency; The color is represented by it.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
