Understanding Electron Orbits: A Physics Problem Explained
  • Thread starter Thread starter bobsmith76
    Electrons Orbit
The discussion centers on the complexities of electron orbits, specifically addressing a physics problem involving an electron's centripetal force around a hydrogen nucleus. It highlights the historical context of using simplified models, like the planetary model, despite their limitations in accurately describing electron behavior. While Newtonian mechanics can provide a mean force calculation, it fails to capture the qualitative aspects of electron motion, which led to the development of quantum mechanics. The Coulomb force is identified as the centripetal force keeping the electron in orbit, but concerns are raised about molecular interactions given this model. Ultimately, the Bohr radius is noted for its significance in defining the binding energy between an electron and a proton.
bobsmith76
Here is a problem from a physics text
An electron (mass 9.11 × 10−31 kg) orbits a hydrogen nucleus at a radius of 5.3 × 10−11 m at a speed of 2.2 × 106 m/s. Find the centripetal force acting on the electron. What type of force supplies the centripetal force?
I'm not interested in the answer, rather I thought that electrons didn't orbit in a Newtonian, viz, predictable fashion. I thought they sort of flew around in their orbits in a manner that only vaguely resembles planetary motion.
There are several models for atoms in physics.
Your textbook is asking you to use one of them.
As students study, they will be asked to learn about simple models before they learn about the complicated ones. The simple ones will usually be historically important, like the planetary model of the atom. They don't have to be true.
You will also find textbooks asking you to do problems in Newtonian mechanics even though we know that they are wrong too... what's the problem?
Well, one can elaborate on this.
When you are asked to calculate the trajectory of a cannon ball in Newtonian mechanics, you know that the theory is applicable - in the sense that the answer is going to be accurate to within a certain number of decimals. However, for electrons orbiting nuclei, common wisdom is that Newtonian mechanics cannot even predict many qualitative features.
On the third hand, Newtonian physics should be OK for the specific quantity asked for here - the mean force on the electron. I think we are really applying Ehrenfest's theorem here (saying that by taking expectation values, an equation in the form of Newton's second law can be derived from the Schrödinger equation).
You've been asked to take a historical trip into the birth-time of Modern Physics. People were trying to get answers from calculations like the one you have been given - then they had to invent QM and beyond.
The answer tells you that the coulomb force pulling the electron towards the proton matches the force needed to turn the electron and keep it in a stable orbit at that distance. The problem with this model, is how is any other molecule going to bind with this one if it has an electron spinning around it.
The Bohr radius of 5.3 × 10−11 m has another very important property. It represents the distance that of the maximum coulomb force that binds a single electron to a single proton. The energy binding a single electron to a single proton never exceeds 13.6 evolts. It is as if the electron does not feel any force from the proton once it is inside this rather large shell. In chemistry it is common to represent the proton as a shell with the size of a bohr radius.
Try a simple game using these principles of a large proton shell together with a tiny electron called "Shoot the Electron".
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
