Understanding Equilibrium Constants 0 & 1
Equilibrium constants of 0 and 1 indicate distinct states in a chemical reaction. An equilibrium constant of 0 suggests that the reaction has not proceeded, resulting in either product concentrations being zero or no reaction occurring. In contrast, an equilibrium constant of 1 signifies that the concentrations of reactants and products are equal, indicating that half of the reactants have been converted into products and the system has reached dynamic equilibrium. The discussion also notes that while Kc = 1 does not imply any special significance, it serves as a boundary case between reactions favoring reactants or products. Understanding these constants helps clarify the behavior of chemical systems at equilibrium.
ycn
Hi, can someone help me on the following question.
Equilibrium constant=0
Equilibrium constant=1
What are the significance of these 2 values? As in, what is happening to the reactants as well as the products in this 2 instances? Thank you!
Write any reaction equation (even as simple as A <-> B), write expression for its equilibrium constant. Then it is simple math - think when equilibrium constant can equal 0 and when it can can equal 1, think in terms of values of concentrations of products and reactants.
But what do the numbers means?
Eg. a + b \Updownarrow c + d
Kc = [c][d]/[a]
Kc = 1 will mean [c][d] = [a]
Kc = 0 will mean either [c] is zero or [d] is zero
1. Is the enthaply change for the reaction zero?
2. Is there no reaction?
3. Is the activation energy zero?
Let's start with the second case. If you start with a and b - what does it mean if c or d is zero? Think about the reaction stichiometry. If c is zero - what about d? How did a and b changed?
That means the other product should have zero concentration. Which also means no reaction would have taken place. Oh okok, thanks a lot, really!
Then in the case for Kc = 1, amount of reactant is equal to the product. That means half of the reactants have been converted into the product, and the reaction has just reached dynamic equilibrium. So can i say it's just a normal equilibrium reaction. Thanks
Sure you can, but it won't hurt to analyse it a little bit further. Think what it does mean when Kc > 1 or Kc < 1. Where the equilibrium lies - on the left, on the right? Kc = 1 doesn't have any special meaning, but it happens to be a border case.
Likes gracy
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
