Understanding Force Formula: ρ AV1 (V1 - V2 cos θ) vs ρ A(V1 - V2 cos θ)
  • Thread starter Thread starter hotjohn
    Forces
The discussion clarifies the formula for calculating force, emphasizing that Fx is given by ρAV1(V1 - V2 cos θ) rather than ρA(V1 - V2 cos θ). This distinction arises from the need to account for the rate of flow, represented as Q, which is crucial for applying Newton's second law to analyze momentum changes over time. The flow rate remains constant across the cross-section, indicating that different velocities exist before and after a bend in the fluid. Consequently, the calculation focuses on the flow rate in the region where both the cross-section and velocity are known. Understanding these principles leads to the correct application of the force formula in fluid dynamics.
hotjohn
  1. why the Fx is given by the formula = ρ AV1 ( V1 - V2 cos θ ) , why not = ρ A( V1 - V2 cos θ ) ?
The force is given by ρQ(v1 - v2cosθ) where Q is the rate of flow. You can understand this by Newton's second law by observing the rate of change of momentum with time. Note that this rate of flow will remain constant throughout the cross-section (which implies that the cross-section after the bend is different than that before the bend because the fluid has different velocities in the two regions). Thus it suffices to calculate the flow rate (Av) in the upper part where the cross-section and velocity is known, Q = A1v1.
Thus you have your desired result.
Likes hotjohn
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
