- #36
PAllen
- 2,430
But then the reverse transform will not be injective. A coordinate transform must be invertible.TrickyDicky said:It is enough for a function with being injective not to map 2 points to 1.
TrickyDicky said:Also this extract from "Spacetime, geometry and gravity (progress in mathematical physics)" textbook seems to confirm what I'm claiming:
"A Word of Warning
One should never, never confuse a diffeomorphism with a coordinate transformation.
A point in a manifold may be described by two charts defined in its
neighbourhood. The coordinates in these respective charts may be, say, xi and yi.
These numbers refer to the same point p. A diffeomorphism Φ maps all points of
the manifold into other points of the manifold. And barring exception a point p
is mapped to a different point q = Φ(p). The points q and p may happen to lie
in the same chart but their coordinates refer to two different points. The relationship
yi = xi + ξi above is therefore not a coordinate transformation but just a
local coordinate expression of the diffeomorphism φ when it happens to be close
to identity.
This caveat is necessary because in many texts this distinction is not emphasized
enough. Physicists define vectors or tensors as quantities which ‘transform’
in a certain way. The formula which gives a change in the components of a vector
when coordinates are changed and the formula above which gives the components
of a pushed-forward vector at q in terms components of the original vector components
at p are similar. Maybe that is why this confusion is prevalent."
There is nothing in this quote that I interpret as suggesting that a coordinate transform is not bijective.
