Understanding Motion Diagrams: Negative vs. Positive Acceleration
  • Thread starter Thread starter Nitrate
    Diagram Motion
The discussion focuses on understanding motion diagrams, specifically differentiating between negative and positive acceleration. Diagram A represents negative acceleration, while Diagram B illustrates positive acceleration. It is clarified that acceleration is a vector quantity, meaning it has both magnitude and direction, and negative acceleration does not necessarily indicate slowing down. There is a question about whether flipping Diagram B would still convey the same information. Overall, the conversation emphasizes the importance of direction in interpreting acceleration in motion diagrams.
Nitrate
The problem is in the attached image
I understand that the diagram of A is displaying negative acceleration and the diagram of B is displaying positive acceleration. However, I am struggling to find an answer for the question. I'm also wondering if the diagram of B can be flipped around and still represent the same thing. I am admittedly not the best physics student and any help is appreciated. Thank you.
attached image (as i forgot to post it in the previous post)
Acceleration is a vector, it has direction. negative acceleration is not the same as slowing down.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
