The discussion clarifies how a wattmeter configuration measures reactive power by responding to the current that is in phase with the voltage. When the power factor is 1.00, the current vector remains at 90 degrees to the voltage vector, but as the power factor decreases, the current vector rotates, affecting the wattmeter's response. The equations presented illustrate the relationship between voltage, current, and power factor in calculating reactive power (VAr) in a three-phase system. A key takeaway is that multiplying the wattmeter reading by √3 is necessary to obtain the three-phase reactive power. This understanding is essential for practical applications in the electrical power industry.
#1
mnada
Does anybody understand how this wattmeter configuration is measuring reactive power?
The wattmeter responds to current that is in phase with the voltage.
In your picture, The reference voltage is Y-B. (picture this vector as horizontal, the base of the delta
triangle). The current is from phase R. Its vector would be vertical or at 90 deg to the voltage vector.
If the power factor is 1.00, then the vector representing current would remain at 90 deg in relation to the voltage vector. As the power factor decreases however, the current vector rotates right or left (inductive or capacitive) and comes closer to being in phase with the voltage vector. As it does, the meter begins to respond. It will measure and display VAr. This is common and has practical application in the electrical power industry.
#3
mnada
Thank you very much, your explanation is crystal clear, and helped me so.
Again, thank you.
#4
m.s.j
212
That varmeter regarding to special connection is a wattmeter inherently, and we can write:
P = K1. VYB . IR . COS ø (output of measurement device)
VYB = √3.VR< 90˚ (In three phase balance system)
P = K1. √3.VR . IR . COS (ø - п/2) = K2. VR . IR . Sin ø
If K2 = 3 we can write:
P = 3. VR . IR . Sin ø = Q3PH
Creative thinking is breezy, Then think about your surrounding things and other thought products. http://electrical-riddles.com
#5
mnada
Another excellent Explanation. Thanks
#6
niko_bellic
you need to multiply \sqrt{3} to the wattmeter reading to get 3-phase reactive power...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
