Understanding Symmetry in Double Integrals
Linday12
Let D be the triangular domain given by 0\leq y \leq3, (y/3)-1 \leq 1-(y/3). Then
\int\int (e-x^{5}e^(sqrt(1+y^2))
There is a quick way to solve it by breaking apart the double integral and then, apparently the x^5 part goes to 0, by symmetry? Anyways, I'm not sure why.
Then I'm left with the double integral of e, and since the domain is just an isosceles triangle, I can multiply the area of it by the e(constant) to get 3e.
So my question is, why does that other part go to zero? I can't visualize it. Knowing this would be a great help. Thank you! (And sorry about the latex, I couldn't quite work it out)
Is the integral supposed to be
\iint_R e - x^5 e^{\sqrt{1+y^2}}dA
and is the region supposed to be
\frac y 3- 1 \le x \le 1 - \frac y 3
If so, yes, it is because of the x5. When you integrate an odd power of x over a symmetric interval [-a,a] you get 0. Set it up as a dx dy integral and you will see.
Yes, that is it. I will make sure to do that. Thank you very much!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
