Understanding the Cat in a Box Paradox
  • Thread starter ArielGenesis
  • Tags
    Box Paradox
In summary: I also said that it is different from being dead or alive.Yes, I think we're on the same page now. The point that I've been trying to make is that the common interpretation of the Schroedinger's Cat paradox is that it is in a superposition of states. That means that ALL of those states exist simultaneously. What seems to be often missed in this is the word "superposition". Many people would say that the cat is either dead OR alive, and we just don't know which one. But that's not what a superposition means.Zz.In summary, the conversation discusses the cat in a box paradox as an analogy for particles in quantum
  • #71
Fra said:
Dany, do you have any yet finished papers where your personal ideas are elaborated?
The paper I referred to in my post above is quant-ph/0606121 entitled “On the connection between classical and quantum mechanics”. It will be published in the HAIT JSE special issue devoted to memory of Prof. I.D.Vagner.
The related papers are:
1)physics/0504008 entitled “On the problem of Zitterbewegung of the Dirac electron”, HAIT JSE, 1 (3), 411,(2004);
2)“Quantum mechanics of non-abelian waves I”, Hadronic Journal,6, 801(1983).
The first is the corrected version of Ch. IX and the second is Ch.VIII of my Ph.D thesis entitled “Quantum Mechanics of Non-Abelian Waves”, Tel-Aviv University, 1982, unpublished.
Ch. III – Ch.VII was published as the paper written by L.P.Horwitz and L.C. Biedenharn, Ann. Phys., 157, 432 (1984).
I discuss ideas here at PF. All mentioned papers discuss mathematical results only. They use fairly advanced extensions of the functional analysis.
Not yet finished papers are:
1) On the “eigenschaften” operators in QM; finished, not written;
2) The squeezed states, the coherent states, etc.; perhaps finished, not written;
3) On relativistic QM; not finished, not written.
I understand that you are interesting in the problems of statmech. I do not believe that I will ever consider the description of more than N=3 states.
Regards, Dany.
  • #72
Demystifier said:
But this is not enough for the consistency of the many-world interpretation. Decoherence alone does not explain why only one of the possibilities is seen by the observers. See e.g.
http://xxx.lanl.gov/abs/quant-ph/0312059 (Rev. Mod. Phys. 76, 1267-1305 (2004))
I haven't gone through the paper ZapperZ mentioned, but my understanding is roughly as follows. Look at the state after observation:
|happy scientist>|alive cat> + |sad scientist>|dead cat>
If we denote the first term by |A> and the second by |B>, then decoherence says that |A> and |B> are incoherent, which roughly means that for any observable O we might measure, <A|O|B>[itex]\approx[/itex]0. But as I described in post 33, this means the system is behaving essentially like a classical probabilistic ensemble, and so the results we get by continuing to apply Schrodinger's equation without collapse is the same as if we did assume collapse, ie, where we assume the cat is in a well-defined classical state, just one which we don't initially know.
In particular, |A> and |B> evolve independently: |happy scientist> evolves into |scientist picking up and hugging the cat>, while |sad scientist> independently evolves into |scientist quietly putting cat into a box>. Yes, a superposition still exists, but the two states in the superposition carry on as if it didn't, essentially because the incoherence of the states means there are no interference effects.
The question still remains: what determines which of the outcomes you experience. Evidently, you experience one, and someone else with an equal claim to be called "you" experiences the other. This is really strange, and I haven't heard any satisfying explanation that incorporates consciousness.
But for now, we can carry on noting that if you were to querry any of the different scientist-copies after he's carried out several quantum experiments, chances are very high that he'll have a memory of a world where the laws of quantum probability were closely followed, so the predictions of the theory are solid (in the probabiliistic sense which is the only sense in which QM can be verified).
  • #73
StatusX said:
The problem with the Copenhagen approach from a theoretical point of view is that the act of "measurement" is not well-defined. There are various attempts at nailing this concept down, but none that seem obviously correct.
The difference with the many worlds view, and the reason I favor it, is that there is no collapse, and so the measurement problem disappears. In fact, that's the only real difference between it and the Copenhagen view: there are no extra assumptions, just one less. From simply denying this process and applying the idea of decoherence (which is not an assumption, but a consequence of QM common to all interpretations), the unitary schrodinger equation alone gives rise to phenonmena macroscopic beings would almost certainly interpret as wavefunction "collapse". That's too nice a fact to ignore.
I am trying to understand the next to last sentence in this paragraph. I thought that the MW interpretation and decoherence were very different beasts. Are you saying that one implies the other? I thought that MW did not make use of decoherence and vice versa.
Thanks for the interesting points.
  • #74
ZapperZ said:
Er.. where does it say these things occurs without a collapse? Isn't "decoherence", by definition, implied a gazillion interactions (and thus, collapse) of the system?
I am a bit confused by the last statement. Interactions are equivalent to collapse?? I thought that interactions in the context of decogherence meant entanglement of states and that no collapse ever took place. Maybe I missed completely the point?
  • #75
I wanted to say "loss of coherence" after so many interactions with the surrounding, but then I'm only saying what "decoherence" is. I would consider an "interaction" as a "collapse", because such interaction can in fact tell you the state of a system.
Zz.
  • #76
Here's a quote that explains the gist of it:
wikipedia said:
However, decoherence by itself may not give a complete solution of the measurement problem, since all components of the wave function still exist in a global superposition, which is explicitly acknowledged in the many-worlds interpretation. All decoherence explains, in this view, is why these coherences are no longer available for inspection by local observers. To present a solution to the measurement problem in most interpretations of quantum mechanics, decoherence must be supplied with some nontrivial interpretational considerations (as for example Wojciech Zurek tends to do in his Existential interpretation). However, according to Everett and DeWitt the many-worlds interpretation can be derived from the formalism alone, in which case no extra interpretational layer is required.
Basically, Everett and DeWitt reason that decoherence alone leads to what "local observers" (eg, one of the copies of the scientist) would interpret as irreversible wavefunction collapse. In other words, you could still enforce collapse, but it would be redundant (except from an ontological point of view, where it removes worlds that aren't practically accessible to us). Although decoherence is now widely accepted as a real effect, the validity of DeWitt's argument that it implies MW is still controvertial.
  • #77
good post, X.
When I was first taught of MW, I was given the impression that the branching of worlds was a very random ad hoc alternative to nondeterministic collapse. Now I wonder whether historically it was first proposed with decoherence already in mind.
  • #78
Demystifier said:
a) You don't read what I say. So, let me repeat. The cat cannot be both dead and alive, it is a logical contradiction. Still, it can be in a superposition of dead and alive. In this case, it is neither dead nor alive. Sometimes we say for such a state that the cat is "both dead and alive", but it is simply an incorrect (or imprecise) language.
b) I say it is in the superposition of head and tail (recall that I am still talking within the 1. paradigm, despite the fact that I actually prefer 2.)
By the way, this is my 666th post.
as I am rereading this thread, I want to say that I agree with Demystifier.
This part of the thread was about whether a linear superposition of two states (dead or alive) should be described as "both dead and alive" or "neither dead nor alive". At thi spoint I think that everybody agrees that the most (and maybe only) accurate description is to say that the system is a linear superposition, period. But if one insists on using everyday language, it seems impossible to accurately convey what a quantum linear superposition means. Then it becomes subjective, to a point, what language is used. Still, I personally think that "both dead an alive" is misleading. It would imply that once the measurement is made, and let`s say the outcome is "alive", that the cat "ceased to be dead" since it was both dead and alive before the measurement.
I find the "neither dead nor alive" at the same better and quite unsatisfying.
I would suggest the following as the best description. A cat in the linear superposition of dead and alive is a cat which has the potential of being alive and he potential of being dead.
Just my two cents...
  • #79
So an electron that is in an H2 molecule is neither near one H atom, nor the other.
Where is the electron that somehow has formed the bonding or antibonding? It has formed it, but it isn't here nor there!
And you found this to be "better"?
Zz.
  • #80
Yea, until a few months ago I just assumed it was someone getting carried away with their imagination and the weirdness of QM. Then I read some more about it and realized it's actually the simplest interpretation, in terms of number of assumptions, and more or less resolves the measurement problem. I'm surprised it isn't more popular than it is (I believe it's second to the Copenhagen interpretaion, depending on the kind of physicists you ask)
  • #81
From my years of playing poker and trying to determine my opponents hand via looking for "tells" or ways to figure out if his hand is good or not based on my opponents behavior and the current environment(other information I've gathered such as the cards in my hand and other cards shown or showing). This is indeed the same problem. We can determine if the cat is alive or dead by making simple observations about it's environment whether it being atmospherical or physical. Is the box moving? Is the box shaking? Is the box warm in a particular spot? Is there air in which the cat can breathe?Is the box emitting sound? These are ways to determine if the cat is alive or not.
The same thing is, in theory, true for particle movement just we have not yet found these observations or what to look for regarding the particles environment.
And another question comes in where if 2 particles were entangled across the universe. Would the entanglements affect other traveling particles and entanglements?
  • #82
Did you find out how MWI accounts for the observed probabilities (Born rule)?
  • #83
Some comments.
I read that paper again last night, and while the general idea that any system will attain some level of correlation with the environment, and that there is a selective mutual pressure between environment and the system is right on...
...but like others say, I wouldn't say it solves the collapse as such, beucase OTOH the collapse isn't an issue for me becuse IMO it's simply sort of a bayesian revision due to the limited measurement resolution and finite complexity of memory - I suspect Alan who is a poker will know what I mean - I like the poker analogy too. I see no way around this. Unless you of course reformulate the problem, but the care should be taken because then we might not ask the same question.
Also, if we are consider an observer B that observes a system + observer A, then clearly we are working in two different descriptions. Observer A has not use of B:s information. Sure they can communicate, but then we add time. In my thinking (spacetime aside!) one can't transfer arbitrary amounts between two records arbitrarily. I think the information transfer is part of defining time which implies a locality in terms of information. I am eventually working on an explicit formalism for this but it a lot of things to do left.
Also, I think the assumption that there is strong correlation between the environment and the system in the first place is valid only it they are close to equilibrium - ie that the system is already "stabilized" i the environment. I figure that this is not a valid assuption in the general case. Also if one is to talk about the actual stabilisation process, this takes time, and then the argumentation gets more complicated. Information that is available in the future, is not available now. I see no sense in that argumentation.
I think the paper is interesting in a sense but it does not get rid of the collapse. The fact that C may observe the correlation between A and B the system, and sees a resolution to the collapse problem is an observation with the wrong condition. The fact that A sees a collapse, doesn't mean that everybody sees a collapse. I don't see a problem with that at all.
I think there is an intrinstic limit due to information capacity, which limits the maximum possible entanglement! and this constraint may impose collapses. I think part of the problem is that all the players have incomplete information, and it's NOT due to flawed or incompetent strategies, it's due to the limiting structures to hold correlation information and due to TIME that correlations are a dynamical thing, if you are thrown into a new environment, then you need some time to equilibrate with the environment, which is btw, mutual.
/Fredrik
  • #84
Fra said:
Some comments.
/Fredrik
I'm going to continue with the poker analogy because it's less graphic then a dead cat. :smile:
When I sit down to a new table, I do have a set strategy and you are right. There is a time factor here. But if A has basic knowledge of environment A. And then A is thrown into environment B(or a new poker table with new people) with the knowledge of evironment A and we are observing a simular situation of a poker game. Then A would have the potential to make correct predictions on the opponents cards more so then when A started at evironment A.
Then when A is introduced to environment C and is also a simular situation of a poker game. Then A would have the knowledge of Evironments A and B. And so on and so forth until the rules or stakes of the game are changed.
There is a learning curve of player A which could potentially be humans in the future if we can learn more about environments of particles and less about their actions. This is a plausible solution because we no longer care what the particles are doing, thus we are not limited to just quantums observation problems. I.E double slot experiment.
  • #85
If you know the cats state, the box has been opened (even if the box remains closed). So the box will always remain closed. Unless you smell something funky which opens the closed box that is still shut.
  • #86
Untrue. The smell is the bi product of the box or cat. Thus making these observations is not directly interferring with the state of the cat(particle). I believe your thinking in more philosophical terms.
  • #87
I may not know much about this stuff, but if you do not know the cats state, the box remains closed restricting the gain of such knowledge. Like lim x --> a .
The funky smell was a joke.
  • #88
It's a good question, and I don't think there's a universally accepted answer. One idea would be that if there is a splitting for each quantum microstate of the system, how many of these go one way or the other will be determined by the magntiudes of the different results in the superposition. I don't think this has been rigorously shown though.
  • #89
I think this is a very serious problem of MWI. It means, in fact, that it cannot explain anything. The obtained experimental results must be introduced by hand without any good reason to do so. Compare this with BM where the probabilities follow naturally. As Einstein said, "make everything as simple as possible, but not simpler."
  • #90
nrqed said:
This part of the thread was about whether a linear superposition of two states (dead or alive) should be described as "both dead and alive" or "neither dead nor alive"... But if one insists on using everyday language, it seems impossible to accurately convey what a quantum linear superposition means.
If one insists on using everyday language, consider 2-dim plane and draw two mutually orthogonal axes on it. Then consider some line belong that plane. That line will contain one of the axes if and only if it is identical to that axis and never both. This is the fundamental property of the metric spaces; otherwise Zz may lock his lab and throw away the keys. Also that “what a quantum linear superposition means”.
Yes. Ask Him why. Gmar Hatima Tova!
Regards, Dany.
P.S. Everyday working experience and knowledge of math is required to have instant feeling what is right and what is wrong in the physical theory. If you do not understand something, ask Demy for example or many others here. Your inability to check yourself disturbs me. Why I should believe that you don’t behave similarly in performing your measurements? In addition, we need explanations of the fine features of the experiments in order to understand their true content and neither you nor other experimentalists here do that.
P.P.S. Perhaps, the explanation is: in order the hydrogen atom to be stable. Otherwise, it will be nobody to ask questions.
  • #91
Demystifier said:
Basically, there are two schools of thoughts.
1. Until you look, the cat is neither dead nor alive.
2. It is allways either dead or alive even if you do not look. But in this case, a sort of nonlocal communication between physical objects is possible.
At the moment, nobody knows with certainty which view is the correct one.
The cat does (at least a living one), plus there's the easy way. Just wait about 50 years, and you can assume the cat is dead, without ever receiving any information about what's in the box, other that you've been told that there's a cat inside. It's a poor analogy in my opinion.
From my point of view, there's only one reality, observed or not. As I've posted before, if a man makes a statement in a forest and even if there is no woman to hear him, all women will know that the man will still be wrong.
  • #92
It is not always so. See, for example, Beyond the Standard Model, “Gross Tel Aviv perspective on string” session, post #14.
Regards, Dany.
  • #93
Regards, Dany.
I'm not quite sure what the heck this is. I could easily say the same about your attitude.
I also have not dissed "knowledge of math", so I'm not sure why you are attacking me on this, especially when it is very clear to anyone who has followed my argument on why QM is so difficult for the general public to understand.
And guess what? I really don't have to impress you on my "ability or how I've done my measurements. My publication track record is more than sufficient, and EVERY work that I've done has been verified elsewhere.
And what do you think we've been trying to do here? I HAVE been trying to explain the "features" of the experiment by invoking what the theoretical description is saying. And I've cited similar interpretation done by reputable physicist (unless you don't think people like Tony Leggett is in the same league as you). The FACT that the superposition principle has been conventionally interpreted as having ALL of the properties existing simultaneously isn't MY private invention. For some odd reason, this issue has been severely ignored here.
Read that Leggett paper and read those Delft/Stony Brook experiments. If you believe they made a mistake in interpreting what they have concluded, then put your money where your mouth is and write a rebuttal! Till then, all your claims on here ring hollow.
Zz.
  • #94
The problem here is that using that view, you can't explain or describe the existence of all those phenomena that I've mentioned already: the existence of bonding and antibonding, and existence of the coherence gap in the Delft/Stony Brook experiment, etc. Remember, these experiments tried not the actually measure Observable A, but rather measure Observable B that either do not commute with A, or are not contextual with A. This allows for a detection of the effect of the superposition of observable A. If A is really one a definite value even before measurement (what you claim having only "one reality"), then you will have a tough time to explain those experiments. I haven't seen anyone tried that.
Zz.
  • #95
This is intuitively natural view extrapolated from our experience with the macroscopic and classical world, but that intuition is deceptive when trying to extrapolate it to more general cases.
But if we take the view that an observation is to be treated on the same footing as interactions, one may ask what determines the responses of a particular observer, or what determines particle interactions. If you think that reality determines his response, then if reality is not known, how can it impact our responses?
The poker analogy is pretty good! What determines the actions of player A? It is certainly not the (to him hidden) cards of the other players! Player A makes his decision based on his *expectations* on what cards the others has. The TRUE cards never explicitly enters the dynamics.
This is why it makes perfect sense to me to expect that a particles behaviour is ultimately determined by the particles expectations on the environment, as the environment changes, so does the particles expectations. This is the dynamics.
How will the person outside the box act until it's opened? It's fully aware of the possibilities and will thus act and respond to the factual superposition of possibilities. So in a sense this superposition is real and I think it's stored in the observer microstructure, brain, state and whatever depending on the type of observer (human or not).
But like others have commented, one can observe other things too... vibration of the box etc. And then certainly the collapse will probably be a quick change rather than a discontinuity, but that is only possible if the observer are able to make sow high resolution observations. Suppose the observer is a simple flip/flop device, which can only be in two states. Then this observer does not have the complexity to absorb all the additional information in ambient disturbances. This is why I personally don't find that an acceptable explanation in the general case, while it's certainly valid in special cases.
/Fredrik
  • #96
QM is compatible with a possibility that there is only one reality. However, it is not compatible with the assumption that this reality is not affected by measurements. You can still say that reality does not depend on observation, provided that you make a clear distinction between measurement and observation.
  • #97
What would you propose this distinction be?
/Fredrik
  • #98
Observation involves conscious beings, while measurement does not. Measurement only requires a physical measuring "apparatus", which may or may not be constructed by humans.
  • #99
Ok, I see your perspective.
Personally I don't make a fundamental distinction between a human and a measuring apparatous. I like to think that the difference is one of complexity, and a matter of communication likes aside.
/Fredrik
  • #100
I haven't followed the whole thread, so forgive me any misunderstanding. But isn't this distinction between measurement and observation the state of the art for interpreting quantum mechanics ?
I think no serious experimentalist will claim today that the result of his experiment depends on him observing the apparatus all the time. What should observation mean in this case ? Looking at a computer screen ? Looking at the shiny metal of a vakuum chamber ? Looking at the desk ? Moreover, would our poor experimentalist dare to take a coffee break and leave his apparatus unattended ?
On the other hand, if you get caught in your car for violating the speed limit, the judge will certainly believe you if you say you were in some alternate reality because you did not pay attention to your speedometer...
In my opinion it is quite obvious that quantum mechanical measurement means the physical process that takes place in the apparatus independent of any observer. Have I missed the point ?
  • #101
OOO, I agree with you. Still, many serious physicists, including experimentalists, do not. I think A. Zeilinger would be an example.
  • #102
Actually, I agree with that, provided that a human is also viewed as a physical object. But I make a difference between a human as a physical object and a human as a conscious being. In my opinion, the latter concept cannot be explained in physical terms, at least not yet.
  • #103
StatusX said:
f95toli,
You seem to be using decoherence as a mechanism to remove any superposiiton, and thus collapse the cat's wavefunction. My understanding is that decoherence simply renders the alive and dead states in the superposition incoherenet, so that they no longer interact. world. What are you suggesting really happens, or are you not worried about this?
I think it depends on the description you are using. If you consider a two-level system interacting with a heat bath (which can be bososnic, i.e. ANY form of electromagnetic environment, including thermal fields; you can also easily generalize this in which case the interference terms are all terms [itex] n \neq m [/itex] ) the effect of decoherence is to make the off-diagonal elements go to zero, i.e. you end up with a diagonal density matrix (strictly speaking one should also differentiate between energy relaxation and pure dephasing since this is important experimentally, but never mind).
Note that I am talking about decoherence due to the ENVIRONMENT now, NOT ordinary measurements (however, these system-bath interactions can be interpreted as indirect, ideal measurements; but these are still very different from "opening the box").
Chapter 4 in "The Theory of Open Quantum Systems" by Breuer give a very good overview of the field.
Whether or not I care depends on if I am in the lab or not. In the lab my main concern is to make sure that the system I am measuring is coherent long enough for me to get the information I want; what happens when the system collapses is irrelevant. Hence, whether the MW interpretation is correct or not has, in my opinion, nothing to do with physics UNLESS someone can come up with a way to test it in an actual experiment.
This does not mean that it is not interesting; but in my view all "interpretations" to date have more to do with philosophy than physics (unless they can be tested, at least in principle).
I guess you can say that I (like most experimentalist I know) use Poppers "definition" of a scientific theory, if can't be measured it ain't science.
  • #104
Anonym said:
If you deny the experimental evidence of the collapse, you are simply crazy. The question is not whether it exists but when and where it occurs, when and where the space-time dispersion shrinks to the point.
I am not denying anything. The "collapse" is very real to me (although I don't really like this language) since the systems I work with are only useful BEFORE they collapse.
However, there was, for a long time a discussion about whether or not system with macroscopic degress of freedom (i.e. composed of 10^23 particles) could exhibit quantum coherence or not. This was not settled until the mid-eighthies when the first (conclusive) experiments on macroscopic quantum tunneling were done (using Nb Josephson junctions which are quite big, around 10x10 microns).
Conceptually, there is a big difference between an atom or a molecule (or a field) and an electronic component so big that you can actually see it.
Moreover, these experiments were done just after the Caldeira-Legget formalism had been published, meaning there was a theoretical framework in place that could be used to analyze the data (in the case of a MQT the dissipation can be modeled as a shunting impedance, which is nice since this means that you can make a direct connection between coherence and the quality factor of the Jospehson junction).
There is something called the Legget criterias that can be used to distinguish between macroscopic quantum coherence and classical systems, I am not sure how well known these are but they are described in one of the books I have on macroscopic quantum tunneling (the book by Takagi).
  • #105
Zz.
I personally feel that insisiting that the electron that formed the bonding has to be here or there is to insist on keeping a classical point of view. I would say that no, the electron that forms the bonding is not here or there, it is in this strange quantum superposition which is not well represented by saying "the electron is there and here". The electron is simply in this straneg quantum state which cannot be conveyed, in my opinion, in an appropriate way by simple words other than saying, as I mentioned, that the electron has the potentiality of being observed here or there. But before the observation is made, I feel that saying that the electron is "both here and there" does not convey adequately the meaning of a quantum state. The electron is neither here nor there (in the usual sense of something "being here" or "there"!).
If I would teach "the electron is both in a spin up and spind own state and then I make a measurement and I observe it in the spin up state"
and a student would ask me
"but before the measurement was made, the electron was both in a spin up an dspin down state so did it "stop" being in a spin down state?"
I would feel that the description of being both in a spin up and spin down would have incorrectly conveyed the situation.
But it's a question of semantics so there is not much point arguing. If you feel that describing the electron as being both spin up and spin down is a fair description of a quantum linear superposition, I can't say much more than I disagree. we have to agree to disagree.
Best regards
Patrick
