Understanding the Equation for Waves on a String: Help Needed!
  • Thread starter Thread starter ajmCane22
    String Waves
The discussion focuses on interpreting the wave equation y = (15cm)cos(πx/5.0cm - πt/12s) and sketching it for t = 0. A participant struggles with the notation and calculations, initially obtaining incorrect values for y. Another contributor clarifies that the issue arises from using degrees instead of radians in calculations. By correctly applying the equation with x values, they demonstrate how to find accurate y values, emphasizing the importance of using the correct angle measurement. The conversation highlights common pitfalls in understanding wave equations and the significance of proper calculation methods.
ajmCane22
A wave on a string is described by the following equation: y = (15cm)cos(πx/5.0cm - πt/12s). Sketch this wave from x = 0 to x = 10 cm for the t = 0.
Honestly, I've never seen this notation before. I have no idea how to interpret it. I tried googling some help and now I'm more confused. I tried setting t to 0 and putting different values for x in order to get a value for y, but I get 14.9... for every value of x, which gives me a straight line, and that answer was incorrect. It might be hard to explain this online, but I would appreciate it immensely if somebody would please try. I'm utterly lost.
Then you are doing something wrong in your calculations or choosing to few x's.
For instance, if x = 0 then y = 15, if x = 2,5 then y = 0, if x = 5 then y = -15 and so on.
How are you doing the calculations?
This is what I am doing:
Using x=2.5 for example,
t=0, so...
15 x cos[(pi*2.5)/5.0 - (pi*0)/12]
15 x cos(1.57 - 0)
15 x 0.9996 = 14.99
I'm obviously doing something wrong, because I know for x=2.5 y should equal 0
your calculator is set to degrees, it should be set to radians.
Omg...I feel like a complete moron.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
