Understanding the Force of Two Cubes
  • Thread starter Thread starter Woopa
    Force
The pressure inside the solid cube is zero, while the external pressure is atmospheric at 1.01 × 10^5 Pa. The force exerted by the pressure on one cube is calculated as F = pA, resulting in 6.3 × 10^3 N using the area of one face of the cube. The discussion raises a question about why only one cube's area is considered, suggesting that both cubes should be accounted for, similar to tension in a rope. However, the focus remains on the forces acting on a single cube in the direction normal to its missing face. Understanding these forces clarifies the application of pressure in this scenario.
Woopa
Two hollow cubes of side 25 cm with one face missing are placed
together at the missing face. The air inside the solid
formed is pumped out. Determine the force that is necessary to
separate the cubes.
P=F/A
The solution is :
The pressure inside the solid is zero and outside it equals atmospheric pressure, 1.01 × 10^5 Pa.
Thus, the force is given by: F =pA = 1.01 × 10^5 × (0.25)^2 = 6.3 × 10^3 N
I do not understand why only the area of one cube is used in the solution, should it not be the area of both cubes e.g. Area of 2 cubes = 2 x (0.25)^2?
This is analogous to a rope being pulled with force F at each end. Is the tension F or 2F?
Just consider one cube. What forces act on it in the direction normal to the missing face?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
