I Understanding the Impact of Solar Radiation and Eccentricity on Earth's Climate
Solar radiation received at the same latitude is generally equal, but local climatic conditions can create variations. Factors such as weather patterns, moisture content, and atmospheric particulates influence the actual solar radiation that reaches the ground. For example, areas like the Gobi Desert may experience more sunny days compared to locations like Waverly, Iowa, despite being at the same latitude. Regarding Earth's eccentricity, predictions suggest it will increase over the next 1,000 years, potentially impacting climate patterns. Understanding these dynamics is crucial for assessing future climate changes.
QuarkDecay
I have two questions
(1) If we have two areas, for example one in America and the other on Asia, both with the same latitude φ, which one of the areas will receive more Solar Radiation? Or will it be the same?
(2)
If Earth's eccentricity graph for the past 750k years is this
http://www.michaelmandeville.com/earthchanges/gallery/Climate/eccentricity_graph.gif
based on that, the eccentricity will get increased again in the next 1000 years? And what will that mean for Earth's climate?
Astronomy news on Phys.org
if both at the same latitude, it will be the same ... is there a reason you thought that it would possibly be otherwise ?
Barring climactic variations. e.g. the Gobi desert (~42 degrees north latitude) probably gets more sunny days per year than Waverly, Iowa (~42 degrees north latitude).
Solar radiation is same for both. Differences due to weather differences (rain, clouds, etc.).
Likes davenn
That depends on whether you are measuring solar radiation hitting the top of the atmosphere or solar radiation hitting the soil.
Moisture content of the local atmosphere ...particulates ... dust , sand if the prevailing wind mostly comes from land areas .
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
9K
