I Understanding the proof of Goldstone theorem
  • I
  • Thread starter Thread starter pines-demon
pines-demon
2024 Award
I was reviewing the proof of Goldstone theorem in Aitchinson-Hay book, vol 2, and I do not understand it. It starts by saying that there is some continues symmetry
$$Q=\int \mathrm d^3 x\, J_0 (x)$$
where ##J_\mu## is the Noether current. Then one considers the expectation value ##\langle 0|[Q,\phi(0)]|0\rangle\neq 0 ##. Using the conservation of the current ##\partial^\mu J_\mu =0## and integrating one can show that
\sum_n (2\pi)^3 \delta(\mathbf p_n)\left(\langle 0 |J_0(0)|n\rangle \langle n|\phi(0)|0\rangle e^{-\mathrm i p_{n0}x_0} -\langle 0 |\phi(0)|n\rangle \langle n|J_0(\mathbf x)|0\rangle e^{\mathrm i p_{n0} x_0}\right)\neq0\tag{17.67}
where the sum is over eigenstates ##|n\rangle## and this calculation is shown to be also independent of ##x_0##. Then the book says:
But this expression is independent of ##x_0##. Massive states ##|n\rangle## will produce explicit ##x_0##-dependent factors ##e^{i M_n x_0}## (##p_{n0}\to M_n##, as the ##\delta##-function constrains ##\mathbf p_n=0##); hence, the matrix elements of ##J_0## between ##|0\rangle## and such a massive state must vanish, and such states contribute zero to (17.67). Equally, if we take ##|n\rangle=|0\rangle##, (17.67) vanishes identically.
I do not get the ##|n=0\rangle## case, if it is massive we have the same issue as with the massive ##|n\rangle## , so it has to vanish. But the expression only vanishes identically if it is not massive. I don't get it.
But it has been assumed to be not zero. Hence, some state or states must exist among ##|n\rangle## such that ##\langle 0|J_0|n\rangle\neq 0## and yet (17.67) is independent of ##x_0##. The only possibility is states whose energy ##p_{n0}## goes to zero as their 3-momentum does (from ##\delta(\mathbf p_{n})##). Such states are, of course, massless: they are called generically Goldstone modes. Thus, the existence of a non-vanishing vacuum expectation value for a field, in a theory with a continuous symmetry, appears to lead inevitably to the necessity of having a massless particle, or particles, in the theory.
Can somebody help me understand what is going on? What is zero and what is not? What is so special of the ##|0\rangle## case?
The "mass" is a property of an excitation (particle or quasiparticle) around the vacuum. The vacuum ##|n=0\rangle## itself is neither massive nor massless, that's what makes ##n=0## special. In fact, the energy of the vacuum is defined as zero, ##p_{00}=0##. (If it was not defined so, then the vacuum state would be time dependent in the Schrodinger picture, so the vacuum would not be time-translation invariant.) When we talk of a massive or massless state, we always assume a state with ##n\neq 0##.
Since ##p_{00}=0##, the ##n=0## does not contribute to the sum, so we can take the sum to be taken over states with ##n\neq 0##. How can this sum be time-independent and yet non-zero? It's only possible if ##p_{n0}=0## for some ##n\neq 0##. Since ##{\bf p}_n=0## (due to the ##\delta##-function) we have ##p_{n0}=M_n##, so there must be some excited states ##n\neq 0## with ##M_n=0##. That's the Goldstone theorem.
Likes weirdoguy and PeterDonis
Thank you I was missing that.
But what is this condition of that $$\langle n | J |0\rangle\neq 0$$ why is it important in this derivation?
If it was zero for all ##n##, then the entire sum would be zero, so the symmetry would not be (spontaneously) broken. The Goldstone theorem says that massless excitations appear when the symmetry is broken.
Gotcha, I think I was looking at it as if it was more mysterious than what it is. Thanks
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
