I Understanding Ultrasound Blocking: Effects on Energy, Reflection, and Absorption
  • I
  • Thread starter Thread starter ChrisCOD
    Ultrasound
Placing an aluminum plate between an ultrasound device and its target will significantly affect the ultrasound's ability to reach the target due to reflection and absorption. The aluminum will reflect a portion of the ultrasound energy, while the remaining energy may be absorbed by the plate, depending on the frequency and intensity of the ultrasound. The surrounding air also influences the transmission, as it has a different acoustic impedance compared to aluminum. The exact amount of energy reaching the target can be calculated by considering these factors, including the specific parameters of the ultrasound. Understanding these interactions is crucial for applications utilizing focused ultrasound technology.
ChrisCOD
Please repost this in the schoolwork forums and show your work
TL;DR Summary
Ways of blocking ultrasound
Hello. I have a question in relation to blocking ultrasound. Suppose we have a device which emits ultrasound. Lets suppose that is is focused ultrasound, and it emits it towards a target at a displaced location. The question is, if you place an aluminum plate between the target location and the device, supposing further that the surrounding medium of the aluminum plate is air, what will happen with respect to the ultrasounds ability to reach the target point?
Suppose you characterize the ultrasound in accordance with various parameters such as frequency, intensity, energy and potentially other parameters. How much of the original ultrasound energy would reach the target point considering the aluminum plate that sits between the device and the target point? Include in your answer consideration of reflection as well as absorption and any other mechanisms for the interaction with the ultrasound.
That doesn't sound like a question you came up with. You should post it in the homework forum with an attempt at a solution.
Likes Vanadium 50 and russ_watters
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
