Understanding Van der Waals Equation for Ideal and Actual Gases | Homework Help
  • Thread starter Thread starter babita
    Van der waals
The Van der Waals equation modifies the ideal gas law to account for real gas behavior by incorporating corrections for intermolecular forces and molecular volume. The term V-nb represents the volume available to gas molecules after subtracting the volume occupied by the gas particles themselves. The pressure correction, represented by an^2/V^2, adjusts the pressure to reflect the effects of intermolecular attractions. This equation provides a more accurate description of gas behavior under non-ideal conditions compared to the ideal gas equation. Understanding these corrections is crucial for applying the Van der Waals equation effectively.
babita
(P+ an^2/V^2)(V-nb) = nRT
I'm having some problems in understanding the above equation.
firstly, PV=nRT holds for ideal P and V , so after correction we are writing ideal P and V in terms of measured P and V right?
secondly V-nb is the actual volume not the ideal one. isn't it? if yes what is it doing in the above equation?
please reply...i'm going mad:mad::mad:
No. This is an approximation that is somewhat better than the simple form of the IGE.
V-nb is a correction to the volume that is proportional to the number of moles of gas and has units of volume. Recall that the IGE assumes that gas molecules/atoms are non-interacting and have no "size".
okkk...i was unable to understand the corrections made by van der waals in IGE...would u pls check if I'm getting it right...
in PV=nRT V is the volume that is available to the gas molecules, since at ideal gas conditions(high T and low P) the volume of particles is negligible,we can write the volume as V only...but in other cases we write V-nb taking into account the volume of particles too.
and in PV=nRT P stands for the pressure that gas particles would exert if no inter molecular forces were present...so in ideal conditions this is approximately equal to measured P...in other cases we have to add an^2/V^2
thankyou
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
