Understanding Water Flow in a Leaky Container Using Differentiation
elitewarr
dV/dT = 0.15(300-V)
V is the volume of water in a container at time T. The rate of water flowing into the container is constant at 45 units^3/s. The rate of water leaking is proportional to the volume of water currently in the container. Find the volume of water in the container when T = 20s. Initial volume of water = 0 units^3.
I tried integrating the equation but could not get any further. V is a function of time which means that I have no idea in doing this. Could anyone help me? Thanks.
First of all, what is the proportionality of the water leaking? By your equation, I'm assuming your vessel is losing water with a proportionality constant of 0.15/s?
This is a simple first order differential equation of the form y'[t] + ay[t] = b where differentiation is with respect to time, t. Do you know how to use integrating factors?
Ok. Thanks a lot. I have somewhat an idea of how to solve it.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
