Understanding Wave Reflection on a Fixed Boundary
  • Thread starter Thread starter simon96c
    Hard Wall Wave
In wave reflection at a fixed boundary, the reflected wave is represented as "-f(-x-vt)" due to the inversion of amplitude and direction. The "-f" indicates the wave's profile is flipped upside down, while "-x" reverses the direction of travel. The term "-vt" ensures that the wave continues to move in the correct direction, maintaining the toe-first motion. Understanding these components clarifies the behavior of waves upon reflection. This explanation effectively addresses the confusion surrounding wave reflection at a fixed boundary.
simon96c
Hello everyone,
I am currently studying traveling waves and reflection but I didn't understand a part of my last lesson.
If we consider a string with a loose end and the other end attached to a wall we expect the string to have zero displacement at the wall and to have a reflected wave "-f(-x-vt)" (given that the incident wave is f(x-vt) ).
My question is probably really silly, but I can't understand why the reflected wave is "-f(-x-vt)" and not "-f(x+vt)" (travelling in the other direction, with inverted amplitude).
I hope I chose the right section since this is my first post here!
Thanks in advance to anyone who will reply to this (probably) really silly question!
Science news on Phys.org
Lets say that the wave has the shape that matches the side profile of a shoe. The -f flips the profile up-side-down. The -x changes the direction the wave is moving. But we still want the wave to move toe first, so the -vt has to stay -vt.
Hope that helps.
That helped a lot!
Thank you very much for your reply.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
