Understanding Wavelengths and Fringes
In a Young's double-slit experiment, the center of a bright fringe occurs where the waves from the slits differ in phase by a multiple of π. The equation d * Δy/L = m*λ is used to relate fringe positions to wavelength. One participant argues that each bright fringe corresponds to a full wavelength, equating one wavelength to 2π. While some suggest answers A or G, the consensus is that the correct answer is D, although there is disagreement with one participant believing it should be E. The discussion highlights the importance of understanding phase differences in wave interference patterns.
hidemi
In a Young's double-slit experiment the center of a bright fringe occurs wherever waves from the slits differ in phase by a multiple of:
the answer is 兀.
d * Δy/L = m*λ
I think the answer is E because each bright fringe is differed by a wavelength, in other words, one wavelength is equal to 2π.
(For example, the first bright fringe is d * Δy/L = 1*λ.)
hidemi said:
Homework Statement:: In a Young's double-slit experiment the center of a bright fringe occurs wherever waves from the slits differ in phase by a multiple of:
the answer is 兀.
Relevant Equations:: d * Δy/L = m*λ
I'm thinking the correct answer is "A". Or maybe "G", but I can't be sure. (Because the multiple choice answers are not visible in your post...) :wink:
sorry ,The multiple choices are :
A) π/4, B) π/2 C) 3π/4 D) π E) 2π
The correct answer is D, however I think it should be E.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
