Understanding Work and Energy: A Short Guide
  • Thread starter Thread starter idllotsaroms
    Bead Rest Sliding
The discussion focuses on clarifying concepts of work, energy, speed, and velocity in the context of a physics problem involving potential and kinetic energy. Participants analyze various statements about the speed and acceleration of an object at different points, concluding that speed at points B and D is equal due to their same height. They differentiate between speed and velocity, emphasizing that velocity includes direction, which affects its value. The role of gravitational force and centripetal force in circular motion is also discussed, highlighting how these forces influence acceleration. Overall, the conversation aims to deepen understanding of work and energy principles in physics.
idllotsaroms
http://postimage.org/image/sezpli4pv/
Having some difficulty understanding some concepts of Work and Energy.
W = F * D
KE = 1/2 mv^2
PE = mgh
A) Speed is at B is less than the speed at D, because B has more PE than D
B) False, because there is the force of gravity acting always
C) True, Same location in respect to the graph
D) Less, because force of gravity < 0
E) Less, because B has more PE than H
F) Less, acceleration due to gravity
Looks to me that D is slightly higher than B. Are you saying B is higher? But it's such a small difference I wonder if they're meant to be the same height. (I think you looked at the wrong two points.)
Acceleration is the result of the net force. If you're standing still, gravity is acting on you but it's countered by the floor, so you don't accelerate. But your answer is right for a different reason. What is happening to the velocity at B?
At (A) above you said it was faster at D. But anyway, this question is asking about velocity, not speed. There's a difference - what is it?
Same misunderstanding as your answer (B).
Yes.
It's asking about acceleration in the x direction.
looks to me that d is slightly higher than b. Are you saying b is higher? But it's such a small difference i wonder if they're meant to be the same height. (i think you looked at the wrong two points.)
Yes, sorry they are on the same level, so speed at B is equal to the speed at D
Is it because the bead is moving in a circular motion at that point (semi circle)?
Since they are at the same level, they have the same potential energy, the same kinetic energy, and therefore the same speed So, the velocity at B is equal to D.
At this point would acceleration be greater than 0 because the dip is a semi-circle with centripetal force aimed towards the middle?
Sorry!, the acceleration in the X-direction at H would be equal to zero then, because there is no external horizontal force.
A) Speed is at B is equal to the speed at D, because they are at the same height
B) False, because there is some circular motion downward which is less than 0
C) False, because of directionality (different directions)
D) Greater than, because centripetal force towards the center which in this case is upward (+)
F) Equal to 0, because there are no external forces acting in the horizontal plane.
Yes.
Yes. The direction of movement is changing from up to down, so there's a downward acceleration.
No. Velocity is a vector. Speed is just its magnitude; it also has direction. If the direction is different the velocity is different.
Yes.
Yes.
Thank you for the help Haruspex, I appreciate it!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
