Uniform charged sphere with hole?
In the discussion about a uniformly charged sphere with a hole, the application of Gauss's law is questioned, leading to the suggestion of using superposition instead. The recommended approach involves first calculating the electric field of the original sphere, then determining the field from an oppositely charged sphere representing the hole, and finally summing these two fields. This method allows for the maintenance of electrostatic conditions despite the presence of the hole. The participants confirm this approach as a valid way to analyze the electric field in this scenario. Overall, the consensus is that superposition is a practical solution for this problem.
philipc
Lets say I have a sphere of uniform charge, and a hole was removed any where within the sphere, would Gauss law be usless and I would have to go with superpostion? And I'm wondering how to set the integral in either case.
Thanks
Philip
many times the divergence teorem is hard to apply, then you can try to solve that thinking about the hole has a charge opposite to the complete sphere in order to maintain the electrostatic condition.
If you're trying to calculate the electric field in the case of the sphere "with a hole" in it then I recommend (a) calculate the field for the original charge distribution, (b) calculate the electric field produced by an oppositely charged sphere where the hole is and then (c) adding the results of (a) and (b).
Oh, sorry, I see Diego essentially made the same suggestion!
Thanks, let's see if I'm thinking right here? First I find the efield at the point as though there was no hole. 2) I find the efield of the point do to the smaller sphere using a -charge density. 3) I sum the two efields together to get final results?
Again thanks for your help
Philip
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
