Chemistry Units conversion for solution concentration
The discussion focuses on the units for the equation C = p/RT, where pressure (p) is measured in Pascals (Pa). It clarifies that the unit for concentration (C) can be expressed as Pa J^-1 mol. The conversation emphasizes the need to understand the units of force, which is Newtons (N), and surface area, measured in square meters (m^2), to derive the concentration in mol/L. The participants agree on the importance of correctly converting these units to achieve accurate results. Overall, the thread highlights the relationship between pressure, force, and concentration in solution chemistry.
cheesycheese
concentration units conversion with Pascal
C= p/RT
What are the units for C= p/RT
where p is in Pa
Would it be Pa J^-1 mol ?
and if so, how could I get the concentration in mol/L
Pressure is the force applied to the surface. What is the unit of force? What is the unit of surface?
surface is m^2
Force is N
Now just follow from there.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
