MHB Universal Propeties in Category Theory .... Leinster Lemma 0.7 ....
Math Amateur
MHB
I am reading Tom Leinster's book: "Basic Category Theory" and am focused on Chapter 1: Introduction where Leinster explains the basic idea of universal properties ...
I need help in order to fully understand the proof of Lemma 0.7 ...
Lemma 0.7 and its proof read as follows:View attachment 8333In the above proof by Leinster we read the following:
" ... ... So by the uniqueness part of the universal property of b ... ... "My question is ... isn't this assuming what we are trying to prove ... that is that b is essentially unique ...Help will be appreciated ...
Peter
No, it is given that b and b' have a universal property that means that they have some kind of uniqueness property, using that, you can prove that T and T' are isomorphic.
In this example, you could say that $(T,b)$ has the following universal property:
For every vector space $W$ and every bilinear map $f:U \times V \Longrightarrow T$ there is a unique $\bar{f}:T \Longrightarrow W$ such that $\bar{f} \circ b=f$
So in Lemma 0.7: $(T,b)$ has this universal property
For the vector space $T'$ and the bilinear map $b':U \times V \Longrightarrow T'$, there is a unique map ...
Conversely, $(T',b')$ has also this universal property
For the vector space $T$ and the bilinear map $b:U \times V \Longrightarrow T$, there is a unique map ...
Make a lot of diagrams, see the book.
In the end, you will see that $T \cong T'$
Another Edit
In the book of Bland, in chapter 2.1, you saw the universal property of direct products and direct sums. You can read it and see if you can recognize the universal properties. In Simmons you will see universal properties in chapter 2.5 and others. It is very important
Another Edit
Thanks for a most helpful post Steenis ...
Appreciate your help ...
Will study the example/lemma more carefully ...
Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
