Unix Scripting Help: Enter Inputs and Send Output to File
  • Thread starter Thread starter Quadruple Bypass
    Unix
To create a script that runs a program, inputs data, and outputs results to a file, it's essential to manage standard input correctly. The initial attempt to use the command "./program > file" only redirects standard output, not standard input. To resolve this, two effective methods are suggested: 1. **Using a Temporary File**: Create a temporary file to store inputs, then run the program with this file as input. This involves using commands to create the temp file, write inputs to it, and execute the program while redirecting output to the desired file.2. **Using a Here Document**: This method allows embedding input directly in the script. By using a delimiter (like EOF or another chosen string), multiple lines of input can be provided directly to the program.Both methods successfully redirect standard input and output, enabling the script to function as intended. The here document approach is particularly noted for its simplicity.
Quadruple Bypass
hi! I am trying to create a script that will run a program, enter inputs (this program requires some inputs for it to run), and then send the output to a file. I am stuck on trying to get the script to enter in those inputs :( so far all i have is:
./program > file
<input1>
<input2>
<input3>
and unfortunately this doesn't work. I've tried like a thousand combinations that i thought would work but i can't figure it out. I am pretty sure there is something wrong with the way I am sending the outputs to the file, but i think i might be able to figure that out whereas i have no idea how to get the inputs inputted in correctly. I am new to unix as you can tell. any help is appreciated!
Technology news on Phys.org
Your program could be buggy, you might have forgotten to do chmod +x on your script, you might have forgotten to put #!/bin/bash as the first line of the script (or #!/usr/bin/python or whatever your script interpreter is), you might not have permission to write to the file, or perhaps some other problem. Obviously you should have given more information than "it doesn't work."
Quadruple Bypass said:
./program > file
<input1>
<input2>
<input3>
That works quite nicely -- just not the way you think it should. The shell script command processor (which one? tcsh? bash? something else?) processes the first line by invoking ./program in a subprocess, with stdout redirected to file. What about stdin? Standard input to your shell script is presumably your terminal -- and you have said nothing to change that.
You need to tell your shell script command processor that you want ./program run with standard input from something other than your terminal. There are many ways to do this. Two of them are to
  1. Write your data to a temporary file and run your program with this temporary file as input
  2. Run your program with data embedded in the script.
1. Using a temporary file (assumes csh, tcsh, or something like that)
Code:
set tempfile = `mktemp my_script.XXXXXX`
echo "input 1" >> $tempfile
echo "input 2" >> $tempfile
echo "input 3" >> $tempfile
./program < $tempfile > file
rm $tempfile
2. Using a here document
Code:
./program > file <<EOF
input 1
input 2
input 3
EOF
What if you want to send the string EOF to your program? Simple: Use something other than EOF to demarcate the end of the here document.
Code:
./program > file <<DONE
input 1
input 2
input 3
EOF
DONE
The here document approach is nice and simple in this case.
that worked perfectly, thanks!
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
