Booshh
- 7
- 1
I have this piece of instrumentation that I am trying to model that I am not entirely sure how it functions. I am certain that it is a voltage monitor. It's basically a voltage divider (v_out = .017*v_in) enclosed in a grounded box with two holes on either side for the connections to the voltage divider. One end of the voltage divider has a connector for a coax cable that would lead to an oscilloscope. The other end has a guide that allows the wire connecting to the voltage divider to stick out of the grounded box by about 3mm.
This instrumentation was placed in a pulsed power system that would be producing a great deal of TEM waves that would travel off of various parts of the system.
If it were acting like an antenna I am aware that the TEM waves would induce a current on the 3mm bit of wire. I am unsure the strength or the orientation of the TEM waves that are produced in the system. Does anyone have any insight on how I could initially approach trying to come up with a model? Or suggest an experiment/test that I could set up to see if the instrumentation actually works? (I can't use the pulsed power system in any testing.)
