Unraveling the Equivalence: Chain Rule and Cauchy-Riemann Equations
  • Thread starter Thread starter fredrick08
    Complex
fredrick08
f(z)=u(r,theta)+iy(r,theta)... where x=rcos(theta) and y=rsin(theta), use chain rule to show that \partialu/\partialr=1/r(\partialv/\partial\theta) and \partialv/\partialr=-1/r(\partialu/\partial\theta) are equivelent to the cauchy riemann equations.
CR equations: \partialu/\partialx=\partialv/\partialy and \partialu/\partialy=-\partialv/\partialx
Ok the I am unsure by how i am meant to use the chain rule here? and instead of typing out the dirvative I am goin to just write i.e d/dx..
i did, dz/dr=dz/dx*dx/dr=1(cos(theta) and dz/dtheta=dz/dy*dy/dtheta=rcos(theta)... but that doesn't make sense... its the same as the provided equations without the 1/r.. but if i do the CR equations i get, du/dx=1 and du/dy=0?
Your use of the chain rule is incorrect here.
Since we're talking about functions of several variables, the chain rule must consider all the possible derivatives. So for example:
\frac{\partial u}{\partial x}=\frac{\partial r}{\partial x}\frac{\partial u}{\partial r}+\frac{\partial \theta}{\partial x}\frac{\partial u}{\partial \theta}
ok then, but can i ask how do u do dr/dx and dtheta/dx? since r and theta are part of x?
do i rearrange?? coz r=x/cos(theta)?? then diffrentiate with respect to x?
ok so if i do the chain rule that elib gave... i get (1/cos(theta))*cos(theta)+-1/(r*sqrt(1-x^2/r^2)*-rsin(theta)... but when i do dv/dy i kind of get similar answer, but instead of the x^2 its y^2, and the last term is cos(theta) and not sin(theta)
ok for the x^2 and y^2 values, i subbed in there respecful values x=rcos(theta) y=rsin(theta) then i get...
1+(sin(\theta)/sqrt(1-cos^2(\theta)/r^2))=1+(cos(\theta)/sqrt(1-sin^2(\theta)/r^2)), which clearly does no equal?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
