Java Updating an index variable in Java
The discussion centers around issues with updating the index variable in a Java program designed to manage flashcards. The user is struggling to implement functionality for navigating to the previous and next flashcards after deleting one. They have attempted various methods to set the index but are encountering problems with retrieving the correct flashcard. The code provided shows a FlashCardList class that manages an ArrayList of FlashCard objects, with methods for adding, retrieving, and deleting flashcards. Key issues highlighted include incorrect index manipulation, particularly with the use of increment and decrement operators, which may lead to out-of-bounds errors when accessing the ArrayList. The user seeks hints to resolve the navigation and deletion issues effectively.
Smiles1
For the life of me, I can't figure out why my program won't update the index variable. I've tried setting the index to 0, and then to -1, and to the size of the arrayList - 1. I'm trying to use the index to get the previous and next flashCard in the arrayList to show up.
I have been working on this for HOURS for the last few days and cannot figure out where or what I'm doing wrong. Please give me hints on getting my next and previous buttons to work with the delete. :-(
Thank you!
FlashCardList
Code:
import java.util.ArrayList;
public class FlashCardList {
    private ArrayList<FlashCard> flashCards;
    private FlashCard flashCard;
    private int index;
    private int position = -1;
    FlashCardList() {
        this.flashCards = new ArrayList();
        this.flashCards.add(new FlashCard("test"));
    public void putFlashCard(String textColor) {
        flashCard = new FlashCard(textColor);
        flashCards.add(flashCard);
        System.out.println(flashCards.toString());
        if(flashCards.size() == 1){
        this.index = index + 1;
        else{
            this.index = index++;
    public FlashCard getFlashCard() {
        if (this.index < flashCards.size()) {
            System.out.println("Get current flashCard index " + this.index);
            return flashCards.get(index);
        } else {
            this.index = index--;
            System.out.println("Get current flashCard index " + index);
    public FlashCard getNextFlashCard() {
            System.out.println("Get Next FlashCard index " + this.index);
            return flashCards.get(this.index);
        } else {
            this.index--;
    public FlashCard getPreviousFlashCard() {
            System.out.println("Get previous flashCard index " + this.index);
        } else {
    public int getCurrentIndex(String displayText) {
        for (int i = 0; i < flashCards.size(); i++) {
            if (flashCards.get(i).getTextColor().equals(displayText)) {
                position = i;
                System.out.println(position);
                break;
        return position;
    public void deleteFlashCard() {
        this.flashCards.remove(index);
        System.out.println("DELETE");
    public void exitApplication() {
        System.exit(0);
FlashCardController
Code:
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
public class FlashCardController {
    private FlashCardListUI flashCardListUI;
    private FlashCardList flashCardList;
    FlashCardController(FlashCardListUI flashCardListUI, FlashCardList flashCardList) {
        this.flashCardList = new FlashCardList();
        this.flashCardListUI = new FlashCardListUI();
        flashCardListUI.setCurrentFlashCard(this.flashCardList.getFlashCard().getTextColor());
        class NextFlashCardButtonListener implements ActionListener {
            public void actionPerformed(ActionEvent ae) {
                flashCardListUI.setCurrentFlashCard(flashCardList.getNextFlashCard().getTextColor());
        class AddButtonListener implements ActionListener {
            public void actionPerformed(ActionEvent e) {
                flashCardList.putFlashCard(flashCardListUI.getCurrentFlashCard());
        class BackButtonListener implements ActionListener {
                flashCardListUI.setCurrentFlashCard(flashCardList.getPreviousFlashCard().getTextColor());
         class DeleteButtonListener implements ActionListener {
                flashCardList.deleteFlashCard();
         class EditButtonListener implements ActionListener {
                 //int i = flashCardList.getCurrentIndex();
                 //System.out.println(i);
          class ExitButtonListener implements ActionListener {
                 flashCardList.exitApplication();
        flashCardListUI.nextFlashCardButtonListener(new NextFlashCardButtonListener());
        flashCardListUI.addFlashCardButtonListener(new AddButtonListener());
        flashCardListUI.backButtonListener(new BackButtonListener());
        flashCardListUI.deleteButtonListener(new DeleteButtonListener());
        flashCardListUI.exitButtonListener(new ExitButtonListener());
        flashCardListUI.editButtonListener(new EditButtonListener());
Technology news on Phys.org
Closing thread since it's a duplicate of https://mathhelpboards.com/computer-science-58/using-mvc-delete-element-arraylist-25062.html.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
