Upgrading Heat Lamp Bulbs in Bathroom Installation
  • Thread starter Thread starter rus
Installing red heat lamps in a bathroom 3-in-one fan assembly instead of the standard white heat lamp raises concerns primarily about heat dissipation and fixture compatibility. The existing fixture's design, including its maximum wattage rating, is crucial to determine if it can safely accommodate a higher wattage bulb. Users are encouraged to check for labels inside the fixture or provide datasheets for clarity. Additionally, the electrical load must be considered, as bathroom lighting circuits are typically lightly fused, and higher wattage bulbs may exceed safe limits. An alternative suggestion is to use a dedicated infrared (IR) heater or fan heater mounted on the wall, which can provide effective heating without overloading existing fixtures. Concerns about thermal design and potential heat absorption by glass shades around IR bulbs are also noted, emphasizing the need for appropriate fitment to ensure safety and efficiency.
rus
Is it possible to install red heat lamps in bathroom 3-in-one fan assembly in place of white inefficient heat lamp Supplied to increase bathroom temperature ?
Welcome to PF. :smile:
The limiting factor will be the heat dissipation in the existing fixture. Is it a recessed fixture for the bulb part? Is there a label inside the fixture that specifies the maximum bulb wattage? Can you post a picture of the fixture (use "Attach files" below) or give us a link to the datasheet?
. . . . or even total load, additional to what lights use. In UK, at least, the lighting circuit will be very lightly fused and any serious source of heat will demand higher current than 'lights'. IMO, the solution to warming your bathroom is to use an IR heater or fan heater, mounted on the wall. that would be fed from a handy ring main. 1kW can make a pleasant improvement to your bathing experience. A bit of a pain unless you are happy with (and capable of) that sort of installation.
I really hate the inadequate thermal design of your average lighting unit. But, these days, LEDs elininate the 'cooking smell' that you can get. Another point could be that a glass shade around a replacement IR bulb could absorb a lot of the radiated IR and get hotter than the same power rated light bulb. You'd need to be sure that a fitment would be appropriate for an IR source.
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Thread 'Nonlinear rubberband type thing - "k" dropping fast as it is stretched'
What materials can I try in order to get a curve of displacement versus force that looks somewhat like this.. (of course, there would be a small kink around the origin where the ends of the rubberband are closer together than its length, which is not shown here). I am looking for something that will last at least 100 stretch cycles and is not messy, so for example liquid based colloidal stuff won't be suitable. Is there something one can whip up using silicone and some additive, say? Or...
