Upper bound for first excited state - variational principle
The discussion focuses on solving a quantum mechanics problem related to the upper bound for the first excited state using the variational principle. The user derived expressions for the upper bound energy and found a candidate wavefunction, resulting in an upper bound of 2.423 for the first excited state, while the actual energy calculated using the shooting method was 4.696. The user confirmed the accuracy of their method for the ground state, where the upper bound of 0.68142 was consistent with the exact energy of 0.667986. A key question raised was about the boundary conditions for the first excited state wavefunction, specifically whether the derivative at zero should equal zero. The discussion highlights the importance of correctly applying boundary conditions in variational methods.
lua
Find the upper bound of the first excited energy eigenstate in the quartic potential using variational principle.
Time-independent Schrodinger equation:
-\frac{\hbar}{2m}\frac{\partial^2 \psi}{\partial x^2}+\alpha x^{4} \psi=E \psi
Dimensionless time-independent Schrodinger equation
-\frac{1}{2}\frac{\partial^2 \psi}{\partial u^2}+(u^{4} - e) \psi=0
Variational principle:
E_{1}\leqslant \int_{-\infty }^{\infty }\psi^{*}(x)H\psi(x)dx
I'm solving problem number 5 from https://ocw.mit.edu/courses/8-05-quantum-physics-ii-fall-2013/resources/mit8_05f13_ps2/.
(a) Here I got:
\beta = \frac{\hbar^{\frac{1}{3}}}{(\alpha m)^\frac{1}{6}}
and:
E = \left ( \frac{\alpha \hbar^4}{m^2} \right )^\frac{1}{3}e
(b) Using Scilab I found that for the ground state energy:
e_{0}=0.667986
(c) A candidate wavefunction for the variational principle is:
\psi _{1}=Axe^{-\frac{ax^2}{2}}
(It is chosen to be orthogonal to ##\psi _{0}##.)
Here I got that upper bound for the first excited state is:
h_{1}=\frac{3}{4}\left ( 10^{\frac{1}{3}} + \frac{5}{100^{\frac{1}{3}}} \right )=2.423
(d) But here, by using shooting method, I got that:
e_{1}=4.696
or, the upper bound is less than the actual energy of the first excited state.
I'm not sure what went wrong.
I have to mention that I checked this for the ground state energy. By using the trial wave function:
\psi _{0}=Be^{-\frac{ax^2}{2}}
I got the upper bound for the ground state energy:
h_{0}=\frac{1}{4}\left ( 6^{\frac{1}{3}} + \frac{3}{36^{\frac{1}{3}}} \right )=0.68142
and exact ground state energy obtained by using the shooting method is:
e_{1}=0.667986
which is OK: exact value of the ground state energy is little bellow the upper bound.
The Scilab source follows:
//Solve a second order differential equation
//Y’’= 2(x^4-e)y, y(0)=1 and y’(0)=0
//e0=0.6679863 - dimensionless gruound state energy
funcprot(0)
function dy=f(x, y)
dy(1)=y(2);
dy(2)=2*(x^4-0.6679863)*y(1);
endfunction
x0=0;
xmax=10;
x=x0:0.1:xmax;
y0=1;
dy0=0;
y=ode([y0;dy0],x0,x,f);
clf;
plot(x,y(1,:),"r")
plot(x,y(2,:),"g")
xtitle("$\frac{d^2 y}{dx^2} =2*(x^4-0.6679863)*y $","x","f(x,y)");
legend("x","dy/dx")
What is ##\psi(0)## for the first excited state?
Does ##\psi'(0) = 0## for the first excited state?
Oh!
I did't think of that at all. Thank you!
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
