Usage of General Specific Heats Cp0 and Cv0
  • Thread starter Thread starter messier992
    General Specific
The discussion centers on the confusion surrounding the application of specific heats Cp0 and Cv0 in thermodynamic equations. It highlights the validity of these relationships, which are typically applicable at constant volume and pressure, and questions their use when pressure and volume change linearly. The participants clarify that for an ideal gas, internal energy and enthalpy are functions of temperature alone, making the equations valid despite changes in pressure and volume. Additionally, the introduction of mass between states is addressed, emphasizing the need to account for the change in mass in the equations. Overall, the discussion seeks to clarify the assumptions and derivations involved in using Cp0 and Cv0 in thermodynamic calculations.
messier992
What conditions for usage of the general specific heats?
u2-u1=~Cv0(T2-T1)
h2-h1=~Cp0(T2-T1)
Cv=du/DT at constant volume
Cp=dh/dT at constant Pressure
Q-W=me*he-mi*hi+m2*u
1. I am rather confused about the usage of Cp0 and Cv0 in the solutions to the question below:
242473
In the solution to the depicted question, the solution involves setting up the equation as follows:
Q-W=me*he-mi*hi+m2*ue-m1*u1
-W=-mi*Cp*Ti+m2CvT2-m1CvT1
I don't follow for the second step. How can the transformation of hi, u1, and u2 be valid? I thought the relation between Cp0 and Cv0 only held over an interval due to the nature of the derivation of the equations:
Cv=δu/δT at constant volume => ∫Cvδu=∫δT => u2-u1=~Cv0(T2-T1)
Cp=δh/δT at constant Pressure = ∫Cvδu=∫δT => h2-h1=~Cp0(T2-T1)2. Additionally, what are the conditions for the usage of these equations?
u2-u1=~Cv0(T2-T1)
h2-h1=~Cp0(T2-T1)
I thought they were only valid at constant volume and pressure? In the case above, the pressure/volume changes linearly, are the relations still valid then?
Lastly, mass is also added between states 1 and 2, in the case above. I understand the equation relates specific terms, per unit mass, but does this addition of mass pose a problem?
The assumption is made that, over the temperature range of interest, the heat capacities are constant. If the answer had employed a reference temperature other than absolute zero (say, 27 C, for example), the 2nd equation would have come out the same in the end, but the derivation would have been much more acceptable to you
u2-u1=~Cv0(T2-T1)
h2-h1=~Cp0(T2-T1)
For the special case of an ideal gas, the thermodynamic state functions u and h are functions only of temperature, independent of pressure and volume, so it doesn't matter if the pressure and volume changed.
Well, you need to determine the change in mass ##m_i=m_2-m_1##, so you would write $$m_2=m_1+m_i$$
Thanks for the reply! I am still confused about how hi can transform into Cp*Ti. I know there is a relationship between Δh = Cp(ΔT), but do not know if there is one for h=CpT. Or are there more complicated immediate steps in between the aforementioned Steps 1 & 2 that were not in the solution?
If we let ##T_R## represent some arbitrary datum absolute temperature at which the internal energy per unit mass is ##u_R##, then in the open system (control volume) version of the 1 st law applied to this problem, then we would write $$u=u_R+C_{v0}(T-T_R)$$ and $$h=u+Pv=u+RT=u_R+C_{v0}(T-T_R)+RT=C_{p0}(T-T_R)+u_R+RT_R$$The energy balance would be written as:$$m_2u_2-m_1u_1=m_ih_i+Q-W$$If we then substitute the equations for u and h in terms of the reference temperature ##T_R##, we obtain:$$m_2C_{v0}T_2-m_1C_{v0}T_1+(m_2-m_1)(u_R-C_{v0}T_R)=m_iC_{p0}T_i+m_i(u_R-C_{p0}T_R+RT_R)+Q-W$$But, since ##m_2-m_1=m_i##, the terms involving the reference state temperature ##T_R## and reference state internal energy ##u_R## drop out, and we are left with:$$m_2C_{v0}T_2-m_1C_{v0}T_1=m_iC_{p0}T_i+Q-W$$
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
