Use comparison theorem to show if integral is convergent or divergent
zero13428
int (e^-x)/(x)dx from 0 to infinity
Determine if integral is convergent or divergent2. The attempt at a solution
I assume because the bottom limit is 0 and there is an x in the bottom of the integral that this is going to be divergent but I still have to use the comparison theorem. I'm trying to find a function less then (e^-x)/(x) that also diverges to show that (e^-x)/(x) will diverge but I'm drawing a blank. I've tried messing around with 1/x^2 or just e^-x but both of those are still larger then the original (e^-x)/(x). Any suggestions?
1/x is an interesting function in that it diverges both ways, the integral from 0 to 1 of 1/x is divergent, as is the integral from 1 to infinity (compare this to x^{1/2} and \frac{1}{x^2}). So when trying to do comparison with a 1/x term, it often helps to break up the integral into one from 0 to 1 and one from 1 to infinity, and see on each of those whether it converges or diverges
Ok, so if I can break the function into two parts, as long as one part (in this case 1/x) converges or diverges then the entire function does?
I thought I could only do these type of integrals by picking a function that was larger or smaller and then comparing.
Since this is an improper integral at both limits of integration, that's why you should consider the two intervals (0, 1] and [1, ∞) separately. Try finding whether the integral from (0, 1] converges first.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
