Useful Representations of Log Audio Frequency Spectrum
Generating a logarithmic frequency scale for audio requires balancing resolution across the spectrum, particularly between 20 Hz and 20 kHz. The current method produces excessive resolution in lower frequencies while compressing higher frequencies too much, leading to an impractical distribution of values. Adobe Audition's spectral analyzer appears to use a modified logarithmic scale that expands mid-range frequencies more effectively than a standard logarithmic function. This suggests that a simple logarithmic approach may not adequately represent audio data, as it can lead to unwanted fine resolution in lower frequencies. Exploring alternative scaling methods, such as spline curves, may provide a more effective solution for visualizing audio frequency data.
Deepsatchel
Hi everyone,
So I'm trying to basically generate a list of numbers between 20 and 20,000 (Hz) in log space that will give good resolution to parts of the audio spectrum that matter! After all that is the point of using log scale for frequency in the first place.
The list generator I have at this point gives very fine resolution between 20 and 100 Hz, and when it gets closer to 20kHz, it's counting by the thousands. A good audio log scale should expand the lows and compress the highs, but not to this degree! What I'm doing is unaltered "log," I believe. Here's exactly what my code looks like:
top = 20000
bottom = 20
bands = 12
loop i from 0 to bands
nextBand = 10^((i/bands)*log10(top-bottom+1))-1+bottom;
save the new frequency value to the list...
end loop
The result:
20, 21, 24, 30, 46, 80, 160, 341, 755, 1699, 3854, 8773, 20000.
In practice I will use many more bands. When I use 400 bands (a reasonable use case), I get 96 of them in the 20's! That is way too many. So if straight logarithmic scale is not what's normally used, then what is? I noticed pictures of Adobe Audition's spectral analyzer on Google Images had scales that seemed approximately logarithmic but expanded more in the middle than regular log.
Anyone know about this?
Thanks, Elwood
Example: http://acousticaddicts.com/0001/AllFourSoftD.jpg
Notice how the distance from 100 to 1k is much smaller than the distance from 1k to 10k... What did they do to the scale?
I know I keep harping on and on, but it seems more likely that in fact the Adobe Audition scale is completely unrelated to an actual log function. I've never met a log function that does not hug the y-axis (thus give very fine resolution - small frequency steps) from 0 out to, say, 1. This is what gives the unwanted fine resolution in the lower frequencies. Therefore a mathematical log is not a foolproof choice to present audio data. Instead, probably, Audition splines a curve over a couple points.
It does resemple log space, but not down close to zero.
Any thoughts?
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
