fog37
- 1,569
- 108
- TL;DR Summary
- Understand the use of a modem to connect to an ISP and to the internet
Hello,
I have been thinking about this and would like to se if anyone can provide some validation or corrections:
The internet is a huge network interconnecting smaller networks. The smallest network would be classified as a LAN (local area network). WANs are instead big networks of networks. Different networks that are part of the Internet are interconnected using routers and high data transmission channels. But a router can also connect computers inside the same network...
In the case of a small home network, which is a LAN, the various computers/machines have their own local IP address an communicate with each other using the Ethernet protocol. Beside the Ethernet protocol, the home network also needs a router (which also has an IP address) to allow the communication between the devices (unless there are only 2 devices which we could connect directly). Every home network has a router but also a modem. The modem is need to connect the home network to the ISP: our small LAN becomes then part of the ISP network (formed by all its customers' networks, etc.). The ISP network connects directly to the Internet connecting us to the Internet.
Thanks!
Fog37
- First, why do we really need the modem and why can we not connect the router in our home network to the ISP network? I understand that a modem is a modulator/demodulator. The modem's input signal looks like a square wave with different discrete voltage levels. The modem's output signal is different: the input discrete signal modulates an electrical sinusoidal carrier signal using either FSK, ASK modulation. Why can we not connect to the ISP without using a modem? Why is the modulation necessary? Without modulation, would the input signal lose too much energy while it is transmitted to the ISP premises? I think so. Using a high frequency electrical signal as a carrier prevents loses...Is that correct?
- What would be needed to be able to connect to the internet directly, without engaging the ISP? What kind of specialized equipment does an ISP have? I am trying to envision the type of hardware that is involved...
Thanks!
Fog37
