Automotive Using Elliptical trammel for opposed cylinder engine
  • Thread starter Thread starter The tin man
    Mechanical design
Using an elliptical trammel for an opposed combustion engine design has potential, but it faces challenges, primarily related to bearing lubrication due to high surface velocities. A flat boxer engine with a quadrature crankshaft could offer a more compact alternative. Balancing the assembly at high speeds may prove difficult, as the cylinders would need to be offset, possibly requiring multiple trammels for balance. The design resembles a radial engine but with fewer pins, and without a closely coupled flywheel, a four-piston engine would likely need to be a two-stroke. Overall, while the concept is intriguing, practical engineering issues limit its feasibility.
The tin man
Question I'm sure theirs a reason this hasn't been done but why couldn't you use an elliptical trammel as a design for an opposed combustion engine where 2 cylinders are vertical and 2 horizontal and have the cylinders combust in separate loops wouldn't that technically do the same thing in principle as long as the pressure fed in a loop
Welcome to PF.
You could use an elliptical trammel in a four piston engine.
The reason it is not done is probably because of bearing lubrication problems, due to high surface velocity.
The engine would be more compact if it was built as a flat boxer, with a quadrature crankshaft for the two journals.
Maybe a diagram of your idea would help find references to that style of engine.
I think balancing the assembly at high speed might be difficult as the two cylinders would need to be offset (and the crankshaft as well). Or you would need multiple two-cylinder trammels to balance each other?
Otherwise, it would look a lot like a radial engine with fewer pins needed. In the following animation, the link with the 5 pins would be the rod between the two pistons; The middle of that rod being connected to the crank pin.
(original animated GIF)
I also found this but I have no clue what the engine looks like.
Without a closely coupled flywheel, the four piston engine would need to be of two-stroke design.
Four-stroke radial engines need an odd number of cylinders, usually greater than six.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
