Using Formulas in Sentences for Physics Paper
  • Thread starter Thread starter Turrialba
    Formulas
The discussion focuses on the grammatical structure of a sentence in a physics paper that includes a formula. The original sentence translates well but lacks a clear subject and predicate in English. Participants suggest that using "At time t1 when both objects reach the ground, y1(t1) = y2(t1) = 0" improves clarity by defining "t1" before the equation. It is noted that using "=" as a verb is acceptable in scientific writing. Overall, the emphasis is on ensuring clarity while maintaining standard scientific language.
Turrialba
I am translating a paper about a general physics question. I am not very familiar with physics other than the historical perspective and I am requesting some help with the grammar. I have a sentence that translates perfectly from the original Spanish as follows:
“At the moment of t1 at which both objects reach the ground, y1(t1)=y2(t1)=0.”
In English, a complete sentence requires a subject and a predicate. In the above sentence, the subject would be “y1(t1)”, which I guess I don´t have a problem with. My query is regarding the simple predicate, which in this case would be “=”. All of the English words in this sentence amount to prepositional phrases.
Is this standard use of language in scientific documents in English? Should I change the sentence to read something like, “The formula y1(t1)=y2(t1)=0 is satisfied at the moment…”?
Thank you for your time and polite consideration.
I am not a native speaker, but that should be fine.
"If/When/... [something], a=b" is quite common in mathematics/physics.
Thank you.
I would read "=" as a verb, and "y1 = y2 = 0" as shorthand for "y1 equals zero and y2 equals zero."
I would write the whole sentence as "At time t1 when both objects reach the ground, y1(t1) = y2(t1) = 0".
The reason for putting the "at time t1..." clause first is to explain what "t1" means before it is used in the equation.
Otherwise, you would have to write something like "y1(t1) = y2(t1) = 0, where t1 is the time when both objects reach the ground."
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
