Using LED in fixture designed for Halogen
  • Thread starter Thread starter drdream
    Led
Using an LED bulb in a fixture designed for a 250W halogen bulb poses significant challenges due to voltage differences. The LED bulb is rated at 14.4VAC, while the fixture supplies 24VAC, which could lead to immediate failure of the LED. The discussion highlights a misunderstanding of electrical concepts, specifically regarding ohms and current. Additionally, the need for proper heat management for the LED is emphasized, but it won't compensate for the voltage mismatch. Overall, the LED is incompatible with the existing fixture without significant modifications.
drdream
Hello,
I have a lighting fixture used in stage and entertainment lighting (HES Trackspot) which was designed to use a 250Watt Halogen bulb (Phillips QT8500). The power supplying the bulb is 24VAC. The bulb has two fans underneath.
I have found a LED bulb with comparable lumen output. The bulb is rated at 14.4VAC @ 6.3amps..
I have found an ohms law calculator which says there is a 1ohm difference between the current.. so I just wanted to know if anyone can chime in on this effort. I also know nothing about power supplies, or if the LED is DC or AC current.. I am just thinking as long as I can hack a heatsink for the LED and the current doesn't blow it up.. it would work?
Thanks
your statement "there is a 1 ohm difference between the current" doesn't make sense since ohms and current are not the same thing at all.
At any rate, no it won't work because if the LED bulbpack is rated for 14V and you power it with 24V, it will surely blow out immediately.
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
