Using Modular Arithmetic to Solve Congruence Equations
  • Thread starter Thread starter jreis
    Arithmetic
jreis
Determine whether there is a positive integer k so that the congruence is satisfied.
2k ≡ 1 (mod 11)
gcd(2k,11) = 1
Well, I know the answer is false. Because of Fermat's Little Theorem, 2k ≡ 2 (mod 11)
But I'm not satisfied with this answer. How could I show the answer to #1?
No, Fermat's Little Theorem tells you 2^11=2 (mod 11). That doesn't tell you it's false because you only need to find one value of k such that 2^k=1 (mod 11). What can you do with 2^11=2 (mod 11)?
Modular multiplication is periodic.
Oh good point... I'm not sure, I'm trying to work this out
If 2 =2 mod 11, that means 2=11k+2.
2 times that is 11(2k)+4 =4 mod k.
By fermat's little theorem above, if you repeat that process 10 times, you will get back to 2^11=2 mod 11, and the cycle repeats.
Either 1 mod 11 is in the first 10 powers of 2, or it won't be found in any of them.
You are trying to solve 2^k=1 (mod 11) and you have 2^11=2 (mod 11). Look at those two things and try not to think very hard.
So do what RUber said? I feel like there is a faster way than checking 10 powers of 2... I know the answer is false from doing that. However, you are hinting at something simpler but I really don't know what. I just started learning modules.
You don't need to check the powers of two.
Notice that when you multiply (a mod 11) by two, your result (mod 11) will be 2a.
So you get:
2, 4, 8, 16 = 5 mod 11, 10, 20 = 9 mod 11, ...
If you get back to 2 without seeing 1, there is no power of 2 that will give you 1 mod 11.
However, you may be wondering how you got back to 2 if that is the case.
So you get:
Where are the 10 and 20 coming from?
Multiplying by 2. That's how this works.
16 = 5 mod 11, so 2*16 = 2*5 mod 11= 10 mod 11.
2(10 mod 11)= 2*10 mod 11 = 20 mod 11 = 9 mod 11.
Wait doesn't fermat's little theorem say 210 = 1 mod 11 ? That's all I need right
I am hinting think about dividing 2^11=2 (mod 11) by 2. What does that give you? In general, you can't divide by an arbitrary number modulo something so just think of it as a guess. What is your guess for what 2^10 mod (11) might be? If you can confirm that guess is true, then you are done.
