achraf mecanique
- 3
Hello everyone,
I’m working on a project where I need to use a cylindrical tube with a vacuum pump to suck in mechanical parts. The tube approaches the part, and the vacuum generated by the pump draws the part into the tube. I want to understand how to link the key parameters of the system: the cross-sectional area of the tube, the flow rate of the pump, the suction force generated, and the distance between the part and the tube.
Here’s what I’m trying to model:
Could anyone explain howto use bernoulli equation to solve this problem
Thanks for your help!
- Suction force generated (Pressure difference) using the pump air flow and the tube cross section,
- The maximum distance between the part and the tube at which the part can still be sucked in,
- How to calculate the maximum mass of the part that can be sucked in.
