Electrical Vaillant VRT350 to Tado smart thermostat
  • Thread starter Thread starter k.udhay
    Diy Heating
The discussion centers around replacing a Vaillant VRT350 thermostat with a Tado smart thermostat while addressing specific user requirements. The user seeks a device that allows temperature control via smartphone without affecting the hot water supply. Installation needs to be straightforward, requiring no boiler interaction, and the user prefers a wired system to avoid battery changes. Concerns about Wi-Fi failures and potential freezing of radiator pipes are also raised.It is noted that the existing VRT350 thermostat may require a central heating engineer's expertise to determine the correct configuration for installation. The proprietary nature of Vaillant's system complicates direct comparisons with standard protocols like Opentherm. While most smart systems include batteries, the longevity of these batteries is typically sufficient, making frequent replacements unnecessary. Overall, professional guidance is recommended for installation due to the user's limited technical knowledge.
k.udhay
TL;DR Summary
electronics at all.
Hello,
My house has a Vaillant VRT350 thermostat fixed on wall. I want to change it to a smart thermostat and found Tado to be interesting so far.
Which model should I buy?
Here are my requirements on the device:
1. I want this new device to facilitate me control the desired temperature by my phone.
2. This should "NOT" control my hot water supply for shower. The existing system is already just good.
Here are my requirements on the installation:
1. I am not good with electronics at all. I can only do basic electrical things like connecting lamps & switches. Not at all good with understanding complex circuit diagrams. So, the installation should be simple to replace existing thermostat with Tado. (No touching of the boiler at all)
2. I don't want a system that expects me to change battery at some intervals - Thus, I prefer a wired system.
3. [Question] If there is a wifi failure in peak winter, will the system at least ensure that the radiator pipes don't go below 5°C to avoid freezing.
In internet there was some info. about Opentherm vs relay that I couldn't understand well. Must I really understand it? Any specific concern of not paying attention to that?
Thanks a lot, in advance!
The VRT350 is more than a simple thermostat and can be installed in many different system configurations. In order to install a Tado (or any other) smart thermostat you will need to work out which configuration you have and what other elements of the system need to be replaced by reverse-engineering the existing wiring and comparing it with the installation circuit diagrams for the whole system including the boiler and any controller wired to it.
Given what I have written above, you need to find a central heating engineer to advise you.
I suggest that you drop this requirement: most smart systems have batteries somewhere.
Vaillant use a proprietory system instead of Opentherm, although there is a converter module available. You need to leave this to someone with better knowledge and experience.
With the OP's lack of tech knowledge then there's no alternative. If you already know what you want your system to do then you wouldn't need to pay a lot more than a call-out charge if your existing system is not too elderly. If it is old then he should consider saving a load of running costs b y buying a new one. (Scrambled pronoun s here but no matter.)
As for his problem with replacing / recharging batteries the proprietary wireless thermostats work virtually for ever on two AA cells. He has, presumably come to terms with recharging a smart phone every one or two days and we're talking over a year replacement for a simple, low data rate thermostat. Not an issue. It's like TV remotes.
The idea is to use water to shift the centre of gravity of the pendulum by a small amount. The pendulum rod will have a tube closed at the bottom and open at the top. A second similar tube will be mounted nearby and will act as a reservoir. The water will be transferred using a peristaltic pump driven by a stepper motor and will travel via a thin flexible silicon tube. A loop arrangement will minimise friction at the pendulum's fulcrum. The silicon tube will extend to the bottom of the...
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
