Variation of heat transfer coefficeint with flow rate
In summary, the heat transfer coefficient (htc) increases with flow rate due to the onset of fully developed flow and boundary layers merging. However, as the flow reaches a fully developed state, the htc level out.
sanka
52
Hi all,
Doing some calculations on an air-cooled heat exchanger at the moment and could use some help understanding the variation of air-side heat transfer coefficient (htc) with flow rate. It's more of an intuitive problem really as I'm okay with the math, etc.
So I know that as you increase the air flow rate the htc increases due to increased moleular agitation, there is less thermal resistance, etc. But my question is this, why does the RATE of increase of htc reduce as one infinetly increases air flow rate? For example, if I plot htc Vs flow rate, the slope of the line is quite steep at the beginning (at lower flow rates) giving a sharp increase in htc, but at some point the slope of this line changes. So, even though the htc still increases with flow rate, the increase is not as great as it was at the lower flow rates.
I have been thinking about it and I think it is due to the onset of fully-developed flow and boundary layers merging in the air-flow channel. The merging of these boundary layers contribute a thermal resistance, thus reducing the increase in htc? Thats just my thoughts anyway.
Any help would be appreciated!
Sanka
Unless you are basing this on an experiment covering all the flow regimes it would be difficult to draw that conclusion. Most forced convection models are empirical, but explicitly assume the flow is already fully developed and either laminar or turbulent but generally for cover transition.
It shouldn't be terribly surprising that the heat transfer rate saturates since all the correlations for flow over a laminar flat plate (or undeveloped pipe flow) tend to have a dependence on [itex]Re_x^{1/2}[/itex], which saturates in the same way. Interestingly, the boundary layer grows with this same parameter for a laminar flow. If you look at most of the data for turbulent boundary layers, you see a similar trend where they depend on [itex]Re_x^{4/5}[/itex], which happens to be the parameter with which a turbulent boundary layer grows. That would imply that the saturation effect you describe is likely related to boundary layer growth.
Once the flow is fully developed, the Nusselt number correlates with [itex]Re_D[/itex] so it no longer correlates to the growth of the boundary layer as you would expect since the boundary layers have merged. At that point it's just a matter of how much fluid you are forcing through the channel. As you increase the mass flow rate you have more thermal mass passing through to which or from which you can move heat, but it has less time in the channel during which it can actually transfer that heat, so it's a trade off at higher flow rates and that can lead to saturation.
Likes 1 person
Another comparison you could make is with internal flow problems (which it sounds like this one may be an internal flow, at least in a manner of speaking?) Remember that flow in a pipe or tube develops until it reaches a constant Nusselt number (and effectively a constant htc). The higher the Reynolds number, the faster it develops. So, as your Reynolds number increases in this case, perhaps it's reaching a "fully developed"* state more quickly, and the Nusselt/htc level out. This assumes laminar flow though, I'm not sure what happens with turbulent flow (I'd have to look it up in my convection heat transfer textbook, and I can't remember where to find it).
If your flow is turbulent, you would at least see a jump or a significant change in the Re vs Nu plot at the point where it transitions to turbulent flow. Whether you've gone that far with your Re numbers or not, only you would know.
* Fully developed thermally
Likes 1 person
Thanks for the reply. I was thinking the exact same thing. Intutively it makes sense, I just never saw it explicitly addressed in any textbook or explained in this manner. I know the correlations indicate that the Nu No (essentially heat transfer coefficient) has to level-off at higher Re No's but the correlations are just representing/modelling the physical phemonena. It's nice to understand the actual physics which they are accounting for.
Related to Variation of heat transfer coefficeint with flow rate
1. How does the heat transfer coefficient vary with flow rate?
The heat transfer coefficient typically increases with increasing flow rate. This is because a higher flow rate leads to a greater rate of heat transfer between the fluid and the surface due to increased turbulence and mixing.
2. What factors affect the variation of heat transfer coefficient with flow rate?
The heat transfer coefficient is affected by factors such as the fluid properties (density, viscosity, thermal conductivity), surface geometry, and the flow conditions (velocity, turbulence intensity). These factors can influence the rate of heat transfer and therefore affect the variation of heat transfer coefficient with flow rate.
3. How can the variation of heat transfer coefficient with flow rate be measured?
The heat transfer coefficient can be measured using experimental techniques such as thermocouples, heat flux sensors, or infrared cameras. These methods can provide information on the temperature distribution and heat transfer rate, which can be used to calculate the heat transfer coefficient.
4. What is the significance of understanding the variation of heat transfer coefficient with flow rate?
Understanding the variation of heat transfer coefficient with flow rate is important in many industrial and engineering applications. It can help in the design and optimization of heat exchangers, cooling systems, and other heat transfer equipment. It can also provide valuable insights into the performance and efficiency of these systems.
5. Are there any limitations to the variation of heat transfer coefficient with flow rate?
While the heat transfer coefficient generally increases with flow rate, there are limits to this relationship. At high flow rates, the fluid may reach a state of fully developed turbulence, where further increases in flow rate will have minimal impact on the heat transfer coefficient. Additionally, other factors such as fouling or surface degradation can also affect the variation of heat transfer coefficient with flow rate.
  • Mechanical Engineering
12K
