Varying coefficient of friction
The discussion revolves around a physics problem involving a box sliding on a surface with a varying coefficient of friction. The coefficient starts at 0.100 and increases linearly to 0.600 over a distance of 12.5 meters. Participants emphasize using the work-energy theorem to relate the initial kinetic energy of the box to the work done by friction as it decelerates. One user attempts to derive the distance the box slides before stopping but arrives at an incorrect answer of 3.984 meters. The conversation highlights the importance of correctly applying the relationship between kinetic energy and the varying friction force.
eeriana
A box is sliding with a speed of 4.50 m/s on a horizontal surface when, at point P, it encounters a rough section. On the rough section, the coefficient of friction is not constant, but starts at .100 at P and increases linearly with a distance past P, reaching a value of .600 at 12.5m past point P. a) Use the work energy theorem to find how far this
box slides before stopping.
Work = .5mV1-.5mV2
K= .5mv^2
I am not really sure where to begin, if someone could steer me in the right direction, I would be grateful. I know that the friction area will cause a deceleration until the box stops. I know that the net force of Fx will be the F force in the positive x direction minus the Friction force in the negative x direction. I feel like I need the mass of the box and since it is not given, it must not be necessary and that means I am missing something.
I believe the s vector will be 12.5 since that is the distance of the friction area.
Thanks..
Amy
Since the friction force is related to the coefficient of friction \mu, one can use the fact that the kinetic energy is dissipated by the friction over the distance from P to the point that it stops, where the kinetic energy is of course zero. The friction force is simply \mu(x)*mg.
So the initial KE = 1/2 mv2 = energy dissipated (or work done by friction). Note the mg is constant, but the friction coefficient is a function of x or the distance traveled.
Alright so I did relate that Work is equal to the change in kinetic energy which is also equal to the magnitude of Force times the magnitude of the change in distance.By doing so, I get that the initial Kinetic Energy equals mg(0.04x + 0.1)xThe equation for u(x) = 0.04x + 0.1. The distance traveled during the process is x.When I solve for x, I get the answer 3.984 m, but this seems to be the wrong answer. Does anyone see where I went wrong?
bump*
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
