Vector and partial derivatives
Crazy Gnome
Two charges one located at P at the position (x,y,z) and P' at the position (x',y',z')
Let f= 1/R.
Calculate Fx= partial derivative of f with respect to x.
Calculate Fx'= partial derivative of f with respect to x'.
There are sub question involving the same thing with other variables but if you could help me figure out the first part that should go easy.
I solved R to be = (x-x')i + (y-y')j + (z-z')k... i think that's right but I do not know how to go about finding the partial derivatives of f. I have never really worked with vectors let alone inverse vectors with calculus.
There is no such thing as an 'inverse vector'. I would guess they mean R=|(x,y,z)-(x',y',z')|, Which is R=sqrt((x-x')^2+(y-y')^2+(z-z')^2).
Right, I got that part. But what is a partial derivative of 1/ a vector?
It can't be a vector. 1/'a vector' doesn't make any sense. Are you sure they didn't write 1/|R|? It's just the partial derivative of a scalar function.
Right *bangs head against the wall*. The only difference on the homework sheet between the vector and the magnitude is the vector is in bold. My stupid mistake.
-Thanks
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
