Vector differential identity proof (using triple product)
In summary: This will make it more clear what the nabla operator is acting on, and you will see that it can't just act on any v it wants.
Earthland
28
Need to prove that:
(v⋅∇)v=(1/2)∇(v⋅v)+(∇×v)×v
Vector triple product
(a×b)×c=-(c⋅b)a+(c⋅a)b
I know I could prove that simply by applying definitions directly to both sides. I haven't done that because that is tedious, and I strive for a more elegant proof and thought that triple product would give it to me.
Since we are dealing with operators the order of the vectors is important and applying triple product would give me
(v⋅∇)v=(v⋅v)∇+(∇×v)×v
But it seems to me that (v⋅v)∇≠ (1/2)∇(v⋅v). It can't be right, because (v⋅v)∇still needs to be applied to something, while the left hand of the equation is something definite. And I can't see where the 1/2 should come from.
Is it wrong to apply triple product to this problem? How else could I prove this identity? Any help?
It is wrong to apply the triple product in the way you have done, you need to keep track of which v the differential operator is acting on, which should be the same before and after applying the identity.
I can't quite understand what you mean. I kept track of the order according to triple product definition, but what does it even mean to keep track on the v that ∇ is acting on? I can't just make it act on v where it isn't acting on v.
You cannot simply treat the nabla as if it was a vector. You can do this for the vector structure, but not for what function the differential operator is acting on. The differential operator is always going to act on the v that corresponds to the v that was standing to the right of the nabla in your original expression. Thus the term with both v to the left of the nabla has no meaning unless you realize that the differential operators in this nabla are actually acting on the components of one of the vs.
No, but you have made it not act on v where it should!
That's what I thought also, but I blindly followed the triple product structure provided by wikipedia. So should I just change it to
∇(v⋅v)
But still, 1/2 is missing
Yes, in there the nabla is acting on both vs. You have to relate this to the case where it is only acting on one of them.
This is why I clearly prefer tensor/index notation for deriving vector relations. You get rid of these ambiguities that appear from trying to apply vector relations to nabla operators.
Both v-s produce a scalar field and thus ∇ acting on it produces a vector field, which it must be because another vector is added to it. ∇ acting on only one v means acting on vector field which would produce a tensor field. So there is some kind of relation I should use?
You can either note that the gradient of v^2 is going to be symmetric in terms of which v the nabla acts, or you could simply apply index notation.
Related to Vector differential identity proof (using triple product)
1. What is a vector differential identity?
A vector differential identity is a mathematical relationship between vector operations that is always true regardless of the specific values of the vectors involved.
2. What is the triple product in vector differential identity?
The triple product in vector differential identity is a mathematical expression of the dot product and cross product of three vectors, which can be used to prove various vector identities.
3. How is the triple product used to prove vector differential identities?
The triple product can be used to manipulate and simplify vector equations, allowing for the proof of various identities involving vector operations.
4. What is the significance of the vector differential identity proof?
The vector differential identity proof is significant because it provides a rigorous mathematical foundation for the use of vector operations in various scientific and engineering applications.
5. Are there any limitations to using the vector differential identity proof?
There are some limitations to using the vector differential identity proof, as it assumes that the vectors involved are well-defined and do not have any special properties that could affect the validity of the proof.
