Vector triangle question - please check me on this
  • Thread starter Thread starter bcjochim07
    Triangle Vector
bcjochim07
The vertices of a triangle are given by points A: (2,-7,3) B: (-1,5,8), & C: (4,6,-1) Is this triangle acute, obtuse, or right?
dot product is positive : acute angle
dot product is negative : obtuse angle
My main question is: don't the vectors have to be arranged tail to tail before you can take the dot product to determine the angle between the vectors? That seems to be the way it is defined in my book.
The three vectors that make up the triangle are
AB: [-3,12,5]
AC: [2,13,-4]
BC: [5,1,-9]
AB\cdotAC= (-3)(2) + (12)(13) + (5)(-4)= 130 > 0, so angle BAC is acute.
AC\cdotBC = (2)(5) + (13)(1) + (-4)(-9) = 59 > 0, so angle ACB is acute
(This is the same as CA\cdotCB so they are tail to tail)
BC\cdotAB = (5)(-3) + (1)(12) + (-9)(5) = -48 < 0, but this is not the angle in the triangle, according to the picture I drew. Rather, this is the supplement, so the angle ABC is also acute.
Thus, the triangle is acute. Could somebody check my work please? Thanks.
nota bene: The ABAC, ACBC, & BCAB are supposed to be dot products.
Any ideas? This assignment is due tomorrow, and I'm pretty curious about whether I am doing this problem correctly or not.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
