Vectors - Groundspeed question
  • Thread starter Thread starter kariibex
    Vectors
A plane is flying N45°E at an airspeed of 525 km/h, with wind coming from N60°W at 98 km/h. The initial calculations using the cosine law yielded a ground speed of 483.5 km/h and an angle of 10.1°. After adjusting for the correct angle due to wind direction, the resultant ground speed was recalculated to 558.4 km/h, with a new angle of approximately 9.8°. The final confirmations indicate that the calculations align closely, affirming the method used.
kariibex
A plane is steering N45°E with an airspeed of 525 km/h. The wind is from N60°W at 98 km/h. Find the ground speed and the direction of the plane.
Cosine law, sine law, vector addition/subtraction.
I have attached an image of my diagram (sorry for the messiness!)
I Solved for R using the cosine law:
R^2 = 525^2 + 98^2 - 2(525)(98)cos60°
R^2 = 285229 - 102900cos60
R^2 = 233779
R = 483.5 km/h
As for the angle, theta, I also used the cosine law:
98^2 = 525^2 + 483.5^2 = 2(525)(483.5)cosθ
-499793.25 = -507675cosθ
cosθ = 0.9844
θ = 10.1°
Is my method correct?
Thank you in advance!
R^2 = 233779
R = 483.5 km/h
cosθ = 0.9844
θ = 10.1°
The wind is from N60°W ...
That means the angle you label as 60° should be 60° + 45°.
Thank you for the reply.
Okay, so using 60° + 45°, I calculated my new resultant vector as 558.4 km/hr.
The only issue is when I solve for theta, cosθ = 1.138, which cannot be solved for.
Is there something I'm missing?
What is the equation you have when solving for cos(θ)?
Oh! I'm sorry, I just realized my mistake (substituted the wrong value) :)
Anyways, my new θ turns out to be:
98^2 = 525^2 + 558.4^2 - 2(525)(558.4)cosθ
-577831.5 = -586320cosθ
cosθ = 0.9855
θ = 9.8°
Hopefully my method is correct?
Thank you for all your help, I really appreciate it :)
cosθ = 0.9855
θ = 9.8°
Yup. I got 9.759° .
The working out suggests first equating ## \sqrt{i} = x + iy ## and suggests that squaring and equating real and imaginary parts of both sides results in ## \sqrt{i} = \pm (1+i)/ \sqrt{2} ## Squaring both sides results in: $$ i = (x + iy)^2 $$ $$ i = x^2 + 2ixy -y^2 $$ equating real parts gives $$ x^2 - y^2 = 0 $$ $$ (x+y)(x-y) = 0 $$ $$ x = \pm y $$ equating imaginary parts gives: $$ i = 2ixy $$ $$ 2xy = 1 $$ I'm not really sure how to proceed from here.
