Vectors in Volleyball (finding distance ball will go)
A sand volleyball player needs to hit the ball at a minimum velocity of 28 m/s at an angle of 2 degrees below the horizontal to clear a 2.43-meter net from a distance of 9 meters. The player is 3.25 meters high at the peak of the jump when serving. To determine if the ball will land inbounds 18 meters away, the player can use the calculated velocity and adjust the height and distance parameters in the equations of motion. By finding the time it takes for the ball to hit the ground, the horizontal distance traveled can be calculated. This approach helps confirm whether the ball will land within the court boundaries.
cd79443
A sand volleyball player attempts a jump serve. The player is 9.0 meters away from the net, which is 2.43 meters high. If the volleyball player hits the ball at the top of his jump (where the ball is 3.25 meters above the ground) and hits it an angle of 2 degrees below the horizontal, determine the following:
1) What is the minimum velocity he can hit the ball with and still have it go over the net?
2)If the opposite end of the court is 9 meters behind the net (18 meters from where the server is) will the volleyball land inbounds?
Pythagorean theorem
## x = x_0 + V_y t - 0.5g t^2##
## x = x_0 + v_0x t + 0.5g t^2##
part 1) I think I was able to work out part 1 eventually, I came up with 28m/s but I'm not positive I solved it correctly. It's mostly part 2 that's giving me trouble!
part 2) I've drawn pictures of the triangles which is difficult to illustrate on here. But using the triangles from part one I know that the found vector (hypoteneuse on my triangle) is 28 m/s at 2 degrees below the positive horizontal. From that I found that the x component is 27.9829 m/s and the y component is 0.977 m/s. So all that is found from part 1 (which I'm still not positive about) but I'm not sure how to apply it to part two. I'm not even sure of what variable I'm trying to find! I know that the x component of the vector should be the same as in part 1 (27.9829 m/s) but the y component should be different, which will mean the angle will be different as well. But I'm just not sure where to go from here. Some help would be really appreciated!
cd79443 said:
part 1) I came up with 28m/s
That's what I get.
There are several ways. E.g. using the velocity calculated, find out when it would hit the ground, then see how far it would have traveled horizontally in that time.
Or, having gone to the trouble of finding a formula for the velocity in the first part you could just change the height and distance inputs (from 3.25-2.43 and 9 to 3.25 and 18, respectively) to find out the velocity that it would make it land on the baseline. Compare that with the velocity required to clear the net.
Great, I think I got it now. Thank you so much!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
