Velocity of cyclist undergoing air resistance
The discussion centers on solving a differential equation that models the velocity of a cyclist experiencing air resistance. The equation is simplified to a more manageable form, allowing for the determination of limiting velocities under various conditions. Numerical results indicate that including a viscous term has minimal impact on the limiting velocity in both air and water scenarios. The Reynolds number is considered relevant, suggesting that viscous drag is negligible due to its large value in these cases. Overall, the problem remains complex, with no analytical solution found yet.
Salviati
I'm attempting to solve the differential equation,
\frac{dv}{dt}=\frac{P}{mv}-\frac{1}{2m}C\rho Av^{2}​
where P, \rho, m, A, C are constants.
The differential equation is used to approximate the velocity of a cyclist undergoing air resistance.
It's actually presented as a numerical problem but I'm wondering if it's possible to solve it analytically.
I'm not sure how to classify the ODE. It's not separable, linear nor exact. Not sure how I could use change of variables either.
A first step: Simplify the equation to ##\frac{dv}{dt}=\frac{c}{v}-bv^2## with new constants c=P/m and b=CρA/2.
The limit velocity is given by ##V=\sqrt[3]{\frac{c}{b}}## and we can construct a typical time ##T=\sqrt[3]{\frac{1}{cb^2}}##, write ##v=w V## and ##t=T \tau## to get $$\frac{dw}{d\tau}=\frac{1}{w}-w^2$$
WolframAlpha does not find a solution, so it looks like a hard problem.
Just wondering how you determined the limit velocity to be ##V=\sqrt[3]{\frac{c}{b}}##.
Setting dv/dt=0 gives 0=c/V - bV^2, with the posted solution.
Ah OK.
Thanks, mfb.
So I've gone through the problem numerically and the results that I'm getting are identical, regardless of whether or not I include the viscous term ## -\frac{\eta Av}{mh} ## in the differential equation.
So, without the viscous term,
While with the viscous term,
\frac{dv}{dt}=\frac{P}{mv}-\frac{1}{2m}C\rho Av^{2} -\frac{\eta}{mh}Av​
I've gone through a couple of scenarios:
1) Cyclist in air with the following constants:
## P = 400 W, m = 70kg, C = 0.5, \rho = 1.225 kg/m^{2}, A = 0.33 m^{2}, \eta = 2*10^{-5} Pas, h = 1.5 m, v_{0} = 4 m/s^{2} ##
Here, my calculated limiting velocity is ## 15.818174 m/s^{2} ## for both viscous and non-viscous considerations.
2) Cyclist in water with the following constants:
## P = 400 W, m = 70kg, C = 0.5, \rho = 1000 kg/m^{2}, A = 0.33 m^{2}, \eta = 1*10^{-3} Pas, h = 1.5 m, v_{0} = 4 m/s^{2} ##.
In this case, the limiting velocity due without viscous drag is ## 1.692526 m/s^{2} ##, while with viscous drag, it is: ## 1.692525 m/s^{2} ##.
I've worked out the limiting velocities as you pointed out by hand, mfb, and everything seems to check out...
Would it be correct to consider the Reynold's number in these scenarios? Since the Reynold's number in both of these scenarios is quite large, the viscous drag is negligeable.
Right.
