Velocity vs Speed (What's more relevant here?)
The discussion centers on the distinction between speed and velocity in a problem involving constant acceleration. Participants argue that the problem primarily asks for speed, as it focuses on calculating distance traveled without explicit mention of direction. However, they acknowledge that in the context of constant acceleration, speed and velocity can be treated as equivalent since both are aligned in the same direction. The lack of direction in the problem statement leads to some ambiguity, but it is generally assumed that the motion is linear and unidirectional. Ultimately, the conclusion is that for this specific case, speed and velocity can be used interchangeably.
Slimy0233
5. A particle starts from rest with a constant acceleration.
At a time t second, the speed is found to be 100 m/s and
one second later the speed becomes 150 m/s. Find (a) the
acceleration and (b) the distance travelled during the
(t+1)th second.
##v = {a}{t}##
This is a famous book in India. I was wondering if one could say if the answer should include velocity or speed. I mean, I don't think there are any details which hint at velocity. We are gives speed in the question and we are asked to find out the distance traveled, this hints we are asked to calculate speed, not velocity. Is it right for the author to calculate velocity (I don't think the calculations makes sense for velocity)?
"speed" is fine within the context of the problem. One assumes the "constant acceleration" is linear, so its speed is just the magnitude of the velocity.
You mean like the first sentence in the problem statement ?
Constant acceleration is the reason why the author wrote velocity instead of speed. I mean, in this case (due to constant acceleration) both are equal. PS: This is motion in 1d, but even with 1d there's a problem of which direction it's moving in. Since it's constant acceleration, it has to move in only one direction.
No, I meant they had asked us to calculate the distance travelled. So, I thought, they are asking us the speed (they are, but speed = vel here as you know, so we don't really care what we call it)
edit: Thank you for your help! I consider this solved :)
In this case speed and velocity can be used interchangeably. That's because the particle starts from rest which means that at all times the velocity and the acceleration are in the same direction. The possibility that the particle reverses direction between ##t## and ##t+1~##(s) is excluded.
Likes MatinSAR, Slimy0233, PeroK and 1 other person
Well, since the problem doesn't explicitly state the direction, we don't know how it lines up with a theoretical pre-established reference frame.
Fair enough, technically
But, without further information/sneakiness, "in the direction it started off at" seems a reasonable assumption to use as a positive reference.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
