Venus -- a more attractive target than Mars for human colonization?
In summary, if Venus had an atmosphere similar to that of Mars, it would be less desirable as a target for human colonization because of the conditions on the surface. However, if the atmosphere were to be modified, humans could live there just like they do on Earth.
lifeonmercury
137
If Venus had an atmosphere similar to that of Mars, would Venus then be a more attractive target than Mars for human colonization?
Likes Richard Thackray
Astronomy news on Phys.org
yes and No. yes Venus is the same size, mass as Earth but it is 44 million miles closer to the sun. therefore No Venus has a runaway greenhouse gas atmosphere which is unlikly to change ever! Also the hemisphere facing the sun is constantly at above 400 Celsius.
the conditions are unlikly to change and the atmosphere creates a pressure of 3- 4 x that of Earth's atmospheric pressure.
In conclusion I would say no to habitation of Venus over Mars.
Some thoughts:
  • Getting to Venus: Faster and slightly easier, assuming you use the atmosphere to brake.
  • De-orbiting and landing is more challenging as you start with a much higher orbital velocity (-> more stress for heat shields) and the gravitational attraction is stronger.
  • Communication: A bit easier and faster as Venus is closer than Mars.
  • Length of day: Bad, really bad. Venus days are 117 Earth days long. Without its thick atmosphere, the day side would get very hot (probably not as hot as it is now, but still uncomfortable), while the night side would get really cold. You would have to land close to the poles, bury deep under the surface, or use a lot of power for cooling during the day and a lot of heating during the night. Solar power is also impractical unless you have a massive electricity storage. Mars has a rotation period of 24 hours 30 minutes, which means you don't have all those issues, and you can even have a regular day/night sleep cycle.
  • Access to water: Looks quite easy on Mars, dig a few meters down and extract ice from the ground. Venus doesn't have large water supplies, but this could be different for our hypothetical Venus with a Martian atmosphere.
  • Getting back: You can easily get from Mars back to Earth with a single-stage rocket. You can get back with the same rocket that brought you to Mars (see SpaceX's ITS plans). For Venus this doesn't work. You would need rockets as massive as the rockets for Earth->Venus. Colonization would be a strict one-way trip until the colony is advanced enough to assemble massive rockets.
  • Very long-term considerations: Adding a convenient atmosphere is easier on Mars because Mars is smaller, but on Venus you get more surface area - the effort per surface area is similar. An artificial magnetic field to protect the atmosphere is possible in both cases, but easier on Mars (here the size, the larger distance to sun and the colder climate help a lot). Surface water on Venus: Maybe closer to the poles, where the temperature does not rise that much. Surface water on Mars would be easier.
In terms of size and distance, Venus is better. However, the surface conditions on Venus is much more horrible than that on Mars, especially the atmosphere there. The atmospheric pressure on the surface of the Earth is approximately 1 bar while that on Venus is 93 bar. And the thickness of the atmosphere there is over 200 km. I think the "modification" of Venus is much harder than that of Mars, merely in terms of atmosphere.
See above.
However, viewed in a different way, the problem with Venus is merely that the ground level is too far below the one atmosphere level. At cloud-top level, Venus is the paradise planet.”
The atmosphere of Venus has a sweet spot at 50km altitude where the temperature and pressure are Earth-like and the atmosphere at that level circles the planet in four Earth days.
You cannot land a craft 50 km above the surface of Venus.
With a large craft / habitat / Teflon balloon / cloud city full of air at or near the standard temperature and pressure we like at the Earth's surface... you float nicely at that altitude because atmosphere of Venus at 50km matches that of your living environment. It's warm, 140s F, but just three km higher and the temperature is in the 80s F.
I'm not sure I'd like to live there! Pretty weird. And what would be the point, there are no resources to exploit.
Maybe they could construct the quirkiest hotel ever. Crazier than the Ice Hotel!
But, could we genetically engineer organisms - or I suppose I really mean, evolve new species - to float at that altitude and grow like plants? Collecting dust like some epiphytes do, conserving water like a cactus, having a float bladder like a Man o' War or kelp? It would need to sense and adjust it's altitude. O2 is less dense than CO2, so the bladder could be filled with O2 that it gets from photosynthesis.
If we did, what would the effect be on Venus atmosphere and climate?
We are at least decades away from creating completely new multicellular species. Putting some molecular processes from species A into species B works sometimes (e.g. insulin production), but that's all we can do today.
Venus!? ... Not a good idea! ... (for now)
She may look pretty and attractive from here ..., but ... not even close to friendly when you get there! ...
Related to Venus -- a more attractive target than Mars for human colonization?
1. What makes Venus a more attractive target than Mars for human colonization?
Venus is often considered a more attractive target for human colonization due to its closer proximity to Earth and its similar size and gravity. It also has a thick atmosphere that could potentially be used for protection against radiation and extreme temperatures.
2. Is Venus habitable for humans?
As of now, Venus is not habitable for humans due to its extreme temperatures and toxic atmosphere. However, with advanced technology and terraforming techniques, it is possible that Venus could become habitable in the future.
3. How does the atmosphere of Venus differ from Mars?
The atmosphere of Venus is primarily made up of carbon dioxide with thick clouds of sulfuric acid, making it a hostile environment for humans. In contrast, the atmosphere of Mars is much thinner and is made up of mostly carbon dioxide with traces of nitrogen and argon.
4. What challenges would humans face when colonizing Venus?
The biggest challenges of colonizing Venus would be the extreme temperatures, corrosive atmosphere, and high atmospheric pressure. These conditions would require advanced technology and protective gear for human survival.
5. Are there any ongoing missions or plans for human colonization of Venus?
Currently, there are no ongoing missions or concrete plans for human colonization of Venus. However, there have been proposals for floating habitats in the upper atmosphere of Venus and terraforming projects to make the planet more habitable for humans in the future.
  • Astronomy and Astrophysics
11K
24
69K
