Verify Eigenstates: Solving s_i & m_i Equations
  • Thread starter Thread starter Philip Land
    Eigenstates
The discussion focuses on verifying eigenstates by solving the equations involving spin quantum numbers, specifically s_i and m_i. The equation presented relates to the calculation of eigenvalues for a system of two spin-1/2 particles. It clarifies that for spin-1/2 particles, both s_1 and s_2 equal 1/2, with m values corresponding to +1/2 for the spin-up state and -1/2 for the spin-down state. The clarification helps address confusion regarding the definitions of s_i and m_i in the context of angular momentum. Overall, the thread provides essential insights into the quantum mechanical treatment of spin states.
Philip Land
verify that ##|s=1,m_s=0> = \frac{1}{\sqrt{2}}(| \uparrow \downarrow> + |\downarrow \uparrow >## is an eigenstate of ##\hat{S^2}##
(Drop hats) $$S^2 = S_1^2 + S_2^2 + 2S_{1z}S_{2z} + S_{1+}S_{2-}+S_{1-}S_{2+}$$
I simply use the equation above, and the eigenvalus whish yield:
##\hbar^2 [ s_1(s_1+1) + s_2(s_2+1) + m_1m_2 + \sqrt{s_1(s_1+1) - m_1(m_1+1)}\sqrt{s_2(s_2+1) - m_2(m_2-1)} + \sqrt{s_2(s_2+1) - m_2(m_2+1)}\sqrt{s_1(s_1+1) - m_1(m_1-1)}##
Very straight forward. My issue is that I don't know what ##s_i## and ##m_i## for i=1,2 is? I only have "s" and "m" from the definition in the question.
I recently had the same problem in an exercise but with angular momentum. Please bring me some clarity on this, thanks so much in advance!
Single-particle states ##|\uparrow\rangle## and ##|\downarrow\rangle## are a basis for spin-1/2 particles, therefore ##s_1 = s_2 = 1/2## and, by convention, ##|\uparrow\rangle## corresponds to ##m= +1/2## and, conversely, ##|\downarrow\rangle## to ##m= -1/2##.
I see, thanks for clearing this up!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
